December 20, 2011, 08:26 |
how to see convergence history in openfoam?
Dr Sachin Borse
Rep Power: 14 |
Dear All,
May I know how to plot converegence history in openfoam? |
December 20, 2011, 10:04 |
Steven van Haren
Rep Power: 15 |
The foamLog script will generate xy-files based on the log file generated by the run.
December 23, 2011, 13:00 |
Santiago Marquez Damian
Rep Power: 23 |
There is an old thread which could be helpful (this is the way I monitor residuals):
Tutorial of how to plot residuals ! Regards
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
January 9, 2012, 02:32 |
different timesteps
Rep Power: 14 |
Hello.
I have the same question, however, when I run FoamLog, the outputs files I get are only for the first time-step of my solution, so they only have 1 x-y entry in each of them. I checked the log file and it has many more timesteps..? Kind Regards, Francesco |
December 14, 2012, 14:13 |
Residual at special time step
Rep Power: 14 |
Do you guys know how I can plot residuals at a special time step?
December 14, 2012, 15:47 |
Lieven
Rep Power: 22 |
What do you mean exactly with "at a special time step".
Using the foamLog utility you can plot them in function of the simulated time but I don't know if this is what you want to do... |
December 14, 2012, 15:50 |
Rep Power: 14 |
For example, how can I plot the residuals at t = 5s or so,e other time step?
December 14, 2012, 15:57 |
#9 |
Rep Power: 14 |
or lets say, how can I plot the final residuals as a function of time?
December 24, 2012, 04:53 |
#10 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
http://www.cfd-online.com/Forums/ope...-new-post.html
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
OpenFOAM Convergence | Martin Hegedus | OpenFOAM | 0 | June 22, 2011 19:20 |
OpenFOAM Install problem | masb | OpenFOAM | 3 | May 25, 2009 11:32 |
Critical errors during OpenFoam installation in OpenSuse 11.0 | amscosta | OpenFOAM | 5 | May 1, 2009 14:06 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 09:33 |
