June 5, 2013, 03:46 |
foam to VTK error
kunar
Rep Power: 14 |
hai friends,
i am doing 2d naca0012 airfoil analysis for turbulent case using simplefoam for angle of attack 2. I try to convert results in VTK format,but i got error like this file: /home/kum/freefoam-user-doc/tutorials/incompressible/simpleFoam/airfoil/2/0/nut::boundaryField::airfoil from line 37 to line 38. From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&) in file /build/buildd/freefoam-0.1.0+dfsg/obj-x86_64-linux-gnu/include/finiteVolume/../../../src/finiteVolume/fields/fvPatchFields/fvPatchField/newFvPatchField.C at line 110. FOAM exiting kindly guide me |
June 8, 2013, 16:06 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Kumar,
This isn't enough information to help you Can you share the file "0/nut"? Or can you post what is on the lines 37 and 38 of this file? And just to confirm, did you run simpleFoam with success? Best regards, Bruno PS: I moved your post to a new thread, since the error is different from the other thread.
June 8, 2013, 23:36 |
foam to VTK error
kunar
Rep Power: 14 |
Thanks wyldckat to coming forward to help me.
I successfully run simplefoam and got results for all, i am doing angle of attack of 0,2,4,6,8,10.but problem is to convert VTK format.please see my attached file. |
June 9, 2013, 05:43 |
Bruno Santos
Rep Power: 128 |
Hi Kumar,
OK, the problem seems to be that foamToVTK does not recognise the boundary condition "nutSpalartAllmarasWallFunction". If it were OpenFOAM instead of FreeFOAM, the following steps should work:
Best regards, Bruno
June 10, 2013, 06:01 |
foam to VTK
kunar
Rep Power: 14 |
Hai Bruno,
I unstall freefoam,because again its give the same error, so i install ubuntu 11.10 with openfoam 2.1. but I got this error during mesh conversation fluentMeshtoFoam,please tell me what i have to do? "version to version i get confused,this is final one i install[ubuntu 11.10 with openfoam 2.1]" toshiba@ubuntu:~/openfoam210/tutorials/incompressible/simpleFoam/airFoil2D$ fluentMeshToFoam naca0012.msh fluentMeshToFoam: command not found |
June 10, 2013, 07:12 |
Bruno Santos
Rep Power: 128 |
Hi Kumar,
Which exact OpenFOAM installation instructions did you follow? Best regards, Bruno
June 10, 2013, 11:57 |
foamToVTK
kunar
Rep Power: 14 |
Hi Bruno, i install ubuntu 11.10 with openfoam version 2.1.0
LINK: http://www.openfoam.org/archive/2.1....oad/ubuntu.php |
June 10, 2013, 13:21 |
Bruno Santos
Rep Power: 128 |
Hi Kumar,
What does the file "~/.bashrc" have near the end of the file? Does it only have the following line? Code:
source /opt/openfoam210/etc/bashrc And what about the following command: Code:
icoFoam -help Best regards, Bruno
June 11, 2013, 02:04 |
foamToVTK
#9 |
kunar
Rep Power: 14 |
Thanks Bruno,that step i forgot to did. I run cavity,right now everything works fine.
For airfoil i got another error like this, i did any mistake please let me know /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : fluentMeshToFoam naca0012.msh Date : Jun 11 2013 Host : "ubuntu" fileName::stripInvalid() called for invalid fileName /home/toshiba/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/UntitledFolder/airFoil2D For debug level (= 2) > 1 this is considered fatal Aborted toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/Untitled Folder/airFoil2D$ |
June 11, 2013, 04:28 |
foamToVTK
#10 |
kunar
Rep Power: 14 |
hi bruno, i got the mistake, i change the UntitledFolder to ku, now its work fine, during run the simple foam i got this,
what ever i mention in red colour it shows any error? toshiba@ubuntu:~/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/ku/airFoil2D$ simpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : simpleFoam Date : Jun 11 2013 Time : 14:42:35 Host : "ubuntu" Case : /home/toshiba/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/ku/airFoil2D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model SpalartAllmaras SpalartAllmarasCoeffs { sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cv2 5; } No field sources present SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field nuTilda tolerance 1e-05 Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 0.999993, Final residual = 0.0558381, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0760732, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0991895, No Iterations 39 time step continuity errors : sum local = 0.00119979, global = 6.26709e-16, cumulative = 6.26709e-16 smoothSolver: Solving for nuTilda, Initial residual = 0.999999, Final residual = 0.0701398, No Iterations 4 ExecutionTime = 36.7 s ClockTime = 37 s forces output: forces(pressure,viscous)((257697 5.20299e+06 7.66604e-16),(6.53254 1.33905 -1.89121e-21)) moment(pressure,viscous)((-3.39084e-17 -1.06156e-16 2.50963e+06),(4.47879e-23 -2.14236e-22 0.66735)) forceCoeffs output: Cm = 901.996 Cd = 415.85 Cl = 1857.68 Cl(f) = 1830.84 Cl(r) = 26.8427 Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.623192, Final residual = 0.0517858, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.445407, Final residual = 0.0284221, No Iterations 4 GAMG: Solving for p, Initial residual = 0.711508, Final residual = 0.0608906, No Iterations 11 time step continuity errors : sum local = 0.000802196, global = 1.48748e-15, cumulative = 2.11418e-15 smoothSolver: Solving for nuTilda, Initial residual = 0.258696, Final residual = 0.0187245, No Iterations 4 ExecutionTime = 45.88 s ClockTime = 46 s forces output: forces(pressure,viscous)((168327 3.88357e+06 2.72499e-16),(23.6262 2.65695 -2.24632e-21)) moment(pressure,viscous)((-2.10668e-17 -5.5126e-17 1.89813e+06),(5.34685e-23 -6.75307e-22 1.37948)) forceCoeffs output: Cm = 682.213 Cd = 301.9 Cl = 1385.1 Cl(f) = 1374.76 Cl(r) = 10.3358 I hope everthing is fine its keep on running like this i got cl,cd,cm, please let me what i mention in red colour. Last edited by hhh; June 11, 2013 at 05:50. |
June 15, 2013, 11:21 |
#11 |
Bruno Santos
Rep Power: 128 |
Hi Kumar,
I'll try to answer at least some of these questions on your other thread, where you've asked them again: http://www.cfd-online.com/Forums/ope...hat-means.html Best regards, Bruno
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
