Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
calcFvcGrad
Like Tree7Likes
Old   May 2, 2013, 04:46
Default calcFvcGrad
Nico A. is on a distinguished road
Hello forum users,
I just wanted to use the new FunctionObjects in OF2.2.0. For calculating a gradient field during the simulation, there is the new calcFvcGrad post-Processing FunctionObject. I added it to my controlDict and started the simulation, but I got the following error:
Starting time loop
--> FOAM FATAL ERROR:
Unknown function type calcFvcGrad
Valid functions are :
18
cellSource
faceSource
fieldAverage
fieldCoordinateSystemTransform
fieldMinMax
fieldValueDelta
nearWallFields
patchProbes
probes
processorField
readFields
regionSizeDistribution
sets
streamLine
surfaceInterpolateFields
surfaces
turbulenceFields
wallBoundedStreamLine
    From function functionObject::New(const word& name, const Time&, const dictionary&)
    in file db/functionObjects/functionObject/functionObject.C at line 92.
FOAM exiting
So, does anyone have the solution to run that function? Did I may forgot to load a special lib?
I appreciate any response.
Best regards, Nico
Nico A. is offline   Reply With Quote
Old   May 2, 2013, 05:46
Default not compiled
Okay, I think this function is not compiled by default. So I added the string: "wmake $makeType fvTools" to the Allwmake file in the
$WM_PROJECT_DIR/src/postProcessing/functionObjects directory and I ran it once again.
Unfortunately an error occured:
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file calcFvcDiv/calcFvcDiv.C
Making dependency list for source file calcFvcDiv/calcFvcDivFunctionObject.C
Making dependency list for source file calcFvcGrad/calcFvcGrad.C
Making dependency list for source file calcFvcGrad/calcFvcGradFunctionObject.C
Making dependency list for source file calcMag/calcMag.C
Making dependency list for source file calcMag/calcMagFunctionObject.C
SOURCE=calcFvcDiv/calcFvcDiv.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/usrfem/femsys_local/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -IlnInclude -I. -I/usrfem/femsys_local/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/usrfem/femsys_local/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/calcFvcDiv.o
In file included from calcFvcDiv/calcFvcDiv.C:26:
calcFvcDiv/calcFvcDiv.H:158: error: ISO C++ forbids declaration of 'polyMesh' with no type
calcFvcDiv/calcFvcDiv.H:158: error: expected ',' or '...' before '&' token
make: *** [Make/linux64GccDPOpt/calcFvcDiv.o] Error 1
So finally that is the newer problem and I do not see why? Are there any suggestions for that?
Thanks in advance.
Best Regards, Nico
Old   May 2, 2013, 08:36
Retired Super Moderator
Bruno Santos
Greetings Nico,
All does seem to indicate that the "fvTools" folder wasn't ready for production in OpenFOAM 2.2.0. You can fix this by running the following commands:
cd "$FOAM_SRC/postProcessing/functionObjects/fvTools"
wget "https://raw.github.com/OpenFOAM/OpenFOAM-2.2.x/master/src/postProcessing/functionObjects/fvTools/calcFvcDiv/calcFvcDiv.H" -O calcFvcDiv/calcFvcDiv.H
wget "https://raw.github.com/OpenFOAM/OpenFOAM-2.2.x/master/src/postProcessing/functionObjects/fvTools/calcFvcGrad/calcFvcGrad.H"  -O calcFvcGrad/calcFvcGrad.H
wget "https://raw.github.com/OpenFOAM/OpenFOAM-2.2.x/master/src/postProcessing/functionObjects/fvTools/calcMag/calcMag.H"  -O calcMag/calcMag.H
wclean libso
wmake libso
Here's an example for appending/adding to "system/controDict":
libs            ("libFVFunctionObjects.so"); //this force-loads the library
functions
    myCalc_calcFvcGrad
        type            calcFvcGrad;
        fieldName       "U";
        resultName      "Ug";
Best regards,
Bruno
Old   May 2, 2013, 09:32
Hello Bruno,
thanks for your help. So there was just the class declaration for ployMesh missing, I did not recognize that. Now the tool is running, thanks again.
Best regards, Nico
Old   August 17, 2013, 20:38
JFM
JFM's Avatar
John Anonymous
JFM is on a distinguished road
Send a message via Skype™ to JFM
Good day Wyldckat and Nico
SOLVED-
I needed to update both the fvTools folder plus the fvTools Allmake from Github and recompile the fvTools. This also resulted in a need to update the fvSchemes file - divSchemes by adding div (U) Gauss Linear;
However I would still appreciate some assistance with extracting the cross momentum values from the model. Please?
I have followed the above post and everything appeared to compile successfully, however when attempting to execute interFoam I received the following error output - the model was going to run but the model would not have generated the desired output.
Build  : 2.2.0-5be49240882f
Exec   : interFoam
Date   : Aug 18 2013
Time   : 10:12:55
Host   : "Ubuntu"
PID    : 6685
Case   : /home/john/MEng/OpenFOAM/dataExtraction/laminar
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
--> FOAM Warning :
    From function dlOpen(const fileName&, const bool)
    in file POSIX.C at line 1179
    dlopen error : /opt/openfoam220/platforms/linux64GccDPOpt/lib/libFVFunctionObjects.so: undefined symbol: _ZN4Foam10calcFvcDiv7timeSetEv
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName&, const bool)
    in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
    could not load "libFVFunctionObjects.so"
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Calculating field g.h
No finite volume options present
While asking a questions could you point me in the right direction on extracting (sampling or field) the acceleration terms (cross momentum) from model.
Any assistance will be greatly appreciated.
Kind regards
JFM
Last edited by JFM; August 18, 2013 at 04:26. Reason: Solution to original query, but still seeking assistance with second question
JFM is offline   Reply With Quote
Old   August 18, 2013, 07:03
Bruno Santos
Greetings JFM,
I'm a bit lost on what exactly you mean by "cross momentum"!?
The only thing that comes to mind if force and momentum values that can be calculated with the function objects "forces" and "forceCoeffs": http://foam.sourceforge.net/docs/cpp/a09472.html
You can find practical example files by running the following command:
grep -islR "force" $FOAM_TUTORIALS | grep system
Best regards,
Bruno
Old   August 25, 2013, 04:40
Default convected momentum
JFM
JFM's Avatar
John Anonymous
Thank you Wyldckat
I had a look at this post plus some of the tutorials a suggested, however they do not seem to provide a method to extract the particular information I am after. The 'cross momentum' terms I am looking for are the convective derivative (momentum) terms from the LHS of the momentum equations for the conservative form of the continuum:
LHS x-direction components
du/dt + u.du/dx + v.du/dy + w.du/dz
In particular the momentum terms (for all x, y, z)
v.du/dy + w.du/dz, etc
We believe these terms may potentially have a reasonable influence on the model results for my particular geometry. I also need to determine of the nonOrthogonalCorrectors are related to these terms.
Any assistance or reference to similar posts will be greatly appreciated.
Regards JFM.
Old   August 25, 2013, 06:25
Bruno Santos
Hi JFM,
Those expressions look familiar to me, but I don't remember if I ever saw them explicitly in OpenFOAM
I did a quick search and the source code of the following utility applications might help you create a variant application for calculating what you need:
  • "applications/utilities/postProcessing/velocityField/Q"
    Calculates and writes the second invariant of the velocity gradient tensor.
  • "applications/utilities/postProcessing/stressField/stressComponents"
    Calculates and writes the scalar fields of the six components of the stress tensor sigma for each time.
  • "applications/utilities/postProcessing/velocityField/vorticity"
    Calculates and writes the vorticity of velocity field U.
The SIG Turbomachinery comes to mind: http://openfoamwiki.net/index.php/Sig_Turbomachinery - but after a quick browse through, I couldn't find anything there directly related to this.
edit: You might also some more information in the Programmer's Guide: http://foam.sourceforge.net/docs/Gui...mmersGuide.pdf
Good luck! Best regards,
Bruno
Old   August 3, 2015, 22:18
J.-H. Wang
f0208secretx is on a distinguished road
So after two years, I've been trying to follow this thread because the documentation about calcFvcGrad isn't clear enough for me to figure out how to do this in OF2.4.0. I think in my case the function objects loaded correctly but there is some field pointer seg fault. While I am tracing it down, hope to get some feedback from the community:
controlDict:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         0.90;//60 periodi
deltaT          0.0001;
writeControl    adjustableRunTime;
writeInterval   0.00018;//St=0.21 ; U=42.12 ;f=154.77Hz ; T=0.0065 ; campiono 10 volte nel periodo//EDO:era 0.0001
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression on;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  on;
maxCo           0.8;
maxDeltaT       1;
functions
    #include "forceCoeffs"
    #include "forces"
    #include "calcFvcGrad"
calcFvcGrad:
MycalcFvcGrad
    type            calcFvcGrad;
    functionObjectLibs            ("libFVFunctionObjects.so");
    fieldName       "U";
    resultName      "Ug";
log.pimpleFoam:
Create time
Reading field p
Reading field U
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
kOmegaSSTCoeffs
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
Starting time loop
forceCoeffs forceCoeffs:
    Not including porosity effects
forces forces:
Courant Number mean: 0.554364 max: 22.31
deltaT = 3.52941e-06
Time = 3.52941e-06
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0236453, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0421888, No Iterations 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.08653, No Iterations 15
time step continuity errors : sum local = 5.60174e-07, global = -9.48512e-08, cumulative = -9.48512e-08
GAMG:  Solving for p, Initial residual = 0.280903, Final residual = 0.0268798, No Iterations 8
time step continuity errors : sum local = 6.5367e-07, global = -6.84472e-08, cumulative = -1.63298e-07
PIMPLE: iteration 2
smoothSolver:  Solving for Ux, Initial residual = 0.00380134, Final residual = 1.16777e-06, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 0.00611923, Final residual = 3.01859e-06, No Iterations 3
GAMG:  Solving for p, Initial residual = 0.0745503, Final residual = 0.00624724, No Iterations 13
time step continuity errors : sum local = 1.62808e-07, global = 2.6053e-08, cumulative = -1.37245e-07
GAMG:  Solving for p, Initial residual = 0.023564, Final residual = 9.83063e-08, No Iterations 125
time step continuity errors : sum local = 2.41377e-12, global = 2.45482e-14, cumulative = -1.37245e-07
smoothSolver:  Solving for omega, Initial residual = 2.40296e-05, Final residual = 2.0622e-07, No Iterations 1
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 8.98325e-06, No Iterations 3
ExecutionTime = 0.47 s  ClockTime = 1 s
forceCoeffs forceCoeffs output:
    Cm    = 0.00647428
    Cd    = 601.426
    Cl    = -0.0306757
    Cl(f) = -0.00886359
    Cl(r) = -0.0218122
forces forces output:
    sum of forces:
        pressure : (3734.49 -0.190466 8.01427e-18)
        viscous  : (0.426175 -3.34092e-05 -3.44755e-20)
        porous   : (0 0 0)
    sum of moments:
        pressure : (0.00952331 186.725 0.0022847)
        viscous  : (1.67046e-06 0.0213087 1.30741e-05)
        porous   : (0 0 0)
calcFvcGrad MycalcFvcGrad output:
    writing field Ug
Courant Number mean: 0.0195176 max: 0.579122
deltaT = 4.0107e-06
Time = 7.54011e-06
PIMPLE: iteration 1
[0] #0  [2] #0  Foam::error::printStack(Foam::Ostream&)[1] #0  Foam::error::printStack(Foam::Ostream&)[3] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) at ??:?
[0] #1  Foam::sigSegv::sigHandler(int) at ??:?
[1] #1  Foam::sigSegv::sigHandler(int) at ??:?
[3] #1  Foam::sigSegv::sigHandler(int) at ??:?
[2] #1  Foam::sigSegv::sigHandler(int) at ??:?
[0] #2  ? at ??:?
[1] #2  ? at ??:?
[3] #2  ? at ??:?
[2] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3  Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::T<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #3  Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::T<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3  Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::T<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3  Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::T<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
[1] #4  Foam::incompressible::RASModels::kOmegaSST::divDevReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:?
 at ??:?
[0] #4  Foam::incompressible::RASModels::kOmegaSST::divDevReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const[3] #4  Foam::incompressible::RASModels::kOmegaSST::divDevReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:?
[2] #4  Foam::incompressible::RASModels::kOmegaSST::divDevReff(Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>&) const at ??:?
[0] #5   at ??:?
[1] #5  ? at ??:?
[3] #5   at ??:?
[2] #5   at ??:?
[0] #6  __libc_start_main??? at ??:?
[2] #6  __libc_start_main at ??:?
[1] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #7   at ??:?
[3] #6  __libc_start_main? in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #7   in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #7   at ??:?
[juihsien-Z9PE-D8-WS:06714] *** Process received signal ***
[juihsien-Z9PE-D8-WS:06714] Signal: Segmentation fault (11)
[juihsien-Z9PE-D8-WS:06714] Signal code:  (-6)
[juihsien-Z9PE-D8-WS:06714] Failing at address: 0x3e800001a3a
[3] #7  [juihsien-Z9PE-D8-WS:06714] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7fd036370c30]
[juihsien-Z9PE-D8-WS:06714] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7fd036370bb9]
[juihsien-Z9PE-D8-WS:06714] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7fd036370c30]
[juihsien-Z9PE-D8-WS:06714] [ 3] /opt/openfoam240/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so(_ZN4Foam1TINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldINS_6TensorIdEET_T0_EEEERKSA_+0x11c) [0x7fd03a5d3c9c]
[juihsien-Z9PE-D8-WS:06714] [ 4] /opt/openfoam240/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZNK4Foam14incompressible9RASModels9kOmegaSST10divDevReffERNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE+0x4f) [0x7fd03a1ea6af]
[juihsien-Z9PE-D8-WS:06714] [ 5] pimpleFoam() [0x41cc3d]
[juihsien-Z9PE-D8-WS:06714] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fd03635bec5]
[juihsien-Z9PE-D8-WS:06714] [ 7] pimpleFoam() [0x41ee1e]
[juihsien-Z9PE-D8-WS:06714] *** End of error message ***
??? at ??:?
[juihsien-Z9PE-D8-WS:06715] *** Process received signal ***
[juihsien-Z9PE-D8-WS:06715] Signal: Segmentation fault (11)
[juihsien-Z9PE-D8-WS:06715] Signal code:  (-6)
[juihsien-Z9PE-D8-WS:06715] Failing at address: 0x3e800001a3b
[juihsien-Z9PE-D8-WS:06715] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7f80a5901c30]
[juihsien-Z9PE-D8-WS:06715] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f80a5901bb9]
[juihsien-Z9PE-D8-WS:06715] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7f80a5901c30]
[juihsien-Z9PE-D8-WS:06715] [ 3] /opt/openfoam240/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so(_ZN4Foam1TINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldINS_6TensorIdEET_T0_EEEERKSA_+0x11c) [0x7f80a9b64c9c]
[juihsien-Z9PE-D8-WS:06715] [ 4] /opt/openfoam240/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZNK4Foam14incompressible9RASModels9kOmegaSST10divDevReffERNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE+0x4f) [0x7f80a977b6af]
[juihsien-Z9PE-D8-WS:06715] [ 5] pimpleFoam() [0x41cc3d]
[juihsien-Z9PE-D8-WS:06715] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f80a58ecec5]
[juihsien-Z9PE-D8-WS:06715] [ 7] pimpleFoam() [0x41ee1e]
[juihsien-Z9PE-D8-WS:06715] *** End of error message ***
 at ??:?
[juihsien-Z9PE-D8-WS:06716] *** Process received signal ***
[juihsien-Z9PE-D8-WS:06716] Signal: Segmentation fault (11)
[juihsien-Z9PE-D8-WS:06716] Signal code:  (-6)
[juihsien-Z9PE-D8-WS:06716] Failing at address: 0x3e800001a3c
[juihsien-Z9PE-D8-WS:06716] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7f8d58017c30]
[juihsien-Z9PE-D8-WS:06716] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f8d58017bb9]
[juihsien-Z9PE-D8-WS:06716] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7f8d58017c30]
[juihsien-Z9PE-D8-WS:06716] [ 3] /opt/openfoam240/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so(_ZN4Foam1TINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldINS_6TensorIdEET_T0_EEEERKSA_+0x11c) [0x7f8d5c27ac9c]
[juihsien-Z9PE-D8-WS:06716] [ 4] /opt/openfoam240/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZNK4Foam14incompressible9RASModels9kOmegaSST10divDevReffERNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE+0x4f) [0x7f8d5be916af]
[juihsien-Z9PE-D8-WS:06716] [ 5] pimpleFoam() [0x41cc3d]
[juihsien-Z9PE-D8-WS:06716] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f8d58002ec5]
[juihsien-Z9PE-D8-WS:06716] [ 7] pimpleFoam() [0x41ee1e]
[juihsien-Z9PE-D8-WS:06716] *** End of error message ***
 at ??:?
[juihsien-Z9PE-D8-WS:06717] *** Process received signal ***
[juihsien-Z9PE-D8-WS:06717] Signal: Segmentation fault (11)
[juihsien-Z9PE-D8-WS:06717] Signal code:  (-6)
[juihsien-Z9PE-D8-WS:06717] Failing at address: 0x3e800001a3d
[juihsien-Z9PE-D8-WS:06717] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7f2c209a8c30]
[juihsien-Z9PE-D8-WS:06717] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x7f2c209a8bb9]
[juihsien-Z9PE-D8-WS:06717] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7f2c209a8c30]
[juihsien-Z9PE-D8-WS:06717] [ 3] /opt/openfoam240/platforms/linux64GccDPOpt/lib/libincompressibleTurbulenceModel.so(_ZN4Foam1TINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldINS_6TensorIdEET_T0_EEEERKSA_+0x11c) [0x7f2c24c0bc9c]
[juihsien-Z9PE-D8-WS:06717] [ 4] /opt/openfoam240/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so(_ZNK4Foam14incompressible9RASModels9kOmegaSST10divDevReffERNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEE+0x4f) [0x7f2c248226af]
[juihsien-Z9PE-D8-WS:06717] [ 5] pimpleFoam() [0x41cc3d]
[juihsien-Z9PE-D8-WS:06717] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7f2c20993ec5]
[juihsien-Z9PE-D8-WS:06717] [ 7] pimpleFoam() [0x41ee1e]
[juihsien-Z9PE-D8-WS:06717] *** End of error message ***
mpirun noticed that process rank 1 with PID 6715 on node juihsien-Z9PE-D8-WS exited on signal 11 (Segmentation fault).
Yann Scott likes this.
f0208secretx is offline   Reply With Quote
Old   August 4, 2015, 17:38
Bruno Santos
@f0208secretx: Two quick questions:
  1. Are you able to reproduce the same error with one of OpenFOAM's own pimpleFoam tutorial cases?
  2. Does the crash only occur when you include your "MycalcFvcGrad" function object?
Old   August 4, 2015, 21:34
J.-H. Wang
1. no. I ran the tutorial "pitzDaily" and it went smoothly.
2. yes. crash only occurred when I include the function object "calcFvcGrad".
It seems to be a bug in the kOmegaSST model in the function "divDevReff" (roughly line 345 in kOmegaSST.C). It failed on this call " - fvc::div(nuEff()*dev(T(fvc::grad(U))))".
The weird thing is, at the first time step the solver behaves correctly and gives me the velocity gradient but then the second time step it produces segfault. Still tracking the bug but would appreciate any help...
Old   August 4, 2015, 22:24
J.-H. Wang
I found the direct cause of the crash. It is the last section in my fvSolution, which I modified from other people:
cache
    grad(U);
The whole thing:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-7;
        relTol           0.01;
        smoother         DICGaussSeidel;
        cacheAgglomeration on;
        agglomerator     faceAreaPair;
        nCellsInCoarsestLevel 10;
        mergeLevels      1;
    pFinal
        $p;
        relTol           0;
    "(U|k|omega)"
        solver           smoothSolver;
        smoother         symGaussSeidel;
        tolerance        1e-8;
        relTol           0.1;
        nSweeps          1;
    "(U|k|epsilon|omega)Final"
        $U;
        tolerance       1e-05;
        relTol          0;
PIMPLE
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
cache
    grad(U);
Once I took out this segment it worked. Any idea why? Should I submit a bug report?
Ardali likes this.
Old   August 15, 2015, 17:49
Bruno Santos
Hi f0208secretx,
I was intrigued by this crash and I've finally managed to take the time to diagnose and find a fix for this problem. The bug and fix has been reported here: http://www.openfoam.org/mantisbt/view.php?id=1828
Best regards,
Bruno
Old   August 16, 2015, 09:39
J.-H. Wang
Thanks for taking your time and look into the case. I am curious about two things:
1) the operator "==" is obviously overloaded. Can you point me to a source so I can learn more?
2) does the cache block increase the computation time? by what amounts?
Thanks!
Old   August 16, 2015, 14:05
Bruno Santos
Run this command:
find $FOAM_SRC/OpenFOAM -name "*.H" -type f | xargs grep "operator=="
The breadcrumbs start in the class "GeometricField".
Caching is meant to reduce computation time, because this way the calculation is only done once per time step. How faster does it get? I don't know, but you can time it yourself
Deffusion likes this.
Old   August 17, 2015, 22:24
J.-H. Wang
Thanks. I was referring to a more complete API reference but one can always read the source code ...
Another problem I ran across that's loosely related to gradient computation/IO:
I have velocity gradient output at every time step in binary, compressed format using calcFvcGrad library. I now want to write a custom binary reader to port this data for each time step to other solvers I wrote. I can't seem to find the descriptions of how this binary is formatted anywhere. I need to know precision, order of array (NCell*9 matrix), corresponding vertex/cell position etc. Will appreciate for any help. Thanks.
Run this command:
Old   August 18, 2015, 12:01
Bruno Santos
Quick answers:
You weren't specific enough in the previous post... anyway:
Already asked in another thread: http://www.cfd-online.com/Forums/ope...sor-field.html - where, if time permitting, someone will answer there.
Old   November 11, 2015, 19:04
Angel Monsalve
angelmonsalve is on a distinguished road
Thank you so much, it really helped me!
angelmonsalve is offline   Reply With Quote
Old   March 9, 2016, 02:15
Default coresponding coordination of gradient filed
  #19
Elham
Elham is on a distinguished road
Hello everybody,
I am wondering if I can have the location of each U gradient as well? I mean like the Ug that is written during the simulation can I have the (x,y,z) data for the corresponding gradient filed?
Thanks.
Elham is offline   Reply With Quote
Old   March 13, 2016, 12:03
Bruno Santos
Quick question: What are you talking about exactly?
There are several topics/strategies discussed on this thread. Can you please be more specific about which utility or function object that you thinking about?
