Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
forces calculation on wigley case
Old   May 15, 2013, 15:07
Default forces calculation on wigley case
Vincenzo
T_RAZZO is on a distinguished road
Hello everyone
I am doing simulations on a boat for an internship university and I arrived at the point of having calcolarmi forces.
I read about all threads by adding the relevant command lines in controlDict but the results I get are unacceptable: too small and above all never go to convergence. the flow has a speed of 3m / s.
how can I fix? command lines I add are these:
functions
forces
type forces;
functionObjectLibs ("libforces.so");
patches ("hull_wall");
pName p;
Uname U;
rhoName rho;
rhoInf 1000.0;
COFR (0 0 0)
OutputControl timestep;
outputInterval 1;
log true;
magUInf 3.0;
the name of the patches is that correct? if not, where can I see that right?
the library to which you refer is correct for OpenFOAM 2.2.0 (this is the version I use)?
please help me. I have a sense of urgency!
T_RAZZO is offline   Reply With Quote
[OpenFOAM] Forces Calculation m_f OpenFOAM Post-Processing 13 April 12, 2018 19:16
Forces on wall in unsteady case sondinho FLUENT 4 December 8, 2012 07:55
forces in interFoam Svensson OpenFOAM Post-Processing 2 May 9, 2012 13:31
i need a case file for erosion calculation Mysara Mohyaldinn FLUENT 0 September 24, 2008 22:32
Wigley hull test case giovanni ieria Main CFD Forum 0 November 22, 1999 11:30
