Calculating Torque
Old   June 9, 2013, 09:34
Unhappy Calculating Torque
Aditya
kingmaker is on a distinguished road
Hello I am farely new to OpenFoam. I am using OpenFoam 2.1
I am trying to use MRFSimpleFoam and calculate torque on a rotating body. I found this (http://openfoamwiki.net/index.php/ComputeTorque) program which is for OpenFoam 1.4. But since I am using version 2.1 I cannot compile it. Also I am not quite sure how to use that utility. I want to have torque printed during the simulation in every say 10 time steps or so. Any suggestion will be of very helpful for me.
thanks in advance
kingmaker is offline   Reply With Quote
Old   June 9, 2013, 15:47
Retired Super Moderator
Bruno Santos
Greetings kingmaker,
I tested only with the second file:
Originally Posted by http://openfoamwiki.net/index.php/ComputeTorque
A slightly modified version that computes the torque by reading an MRFZones file is available here: [[2]]
and apparently it is somewhat damaged.
The missing fix is to edit the file "Make/files" and use the following content instead:
computeTorque.C
MRFZoneDrg.C
MRFZonesDrg.C
EXE = $(FOAM_USER_APPBIN)/computeTorqueMRF
Then run the following command from within the "computeTorqueMRF" folder:
wmake
Best regards,
Bruno
Old   July 26, 2013, 00:36
Default evaluating torque in VAWT simulation AMI region
Anand Lobo
Boloar is on a distinguished road
Hi Bruno,
Could you explain, roughly, how this utility works? My programming background is weak at best.
Are there any prerequisites required in the case files or setup for the tool to work?
UPDATE:
I tried to build it as you suggested above, for OpenFOAM 2.2.1. I got this error:
$ wmake
/opt/openfoam221/wmake/wmake: 222: /opt/openfoam221/wmake/wmake: make: not found
/opt/openfoam221/wmake/wmake: 223: /opt/openfoam221/wmake/wmake: make: not found
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/admin/Documents/computeTorqueMRF
Boloar is offline   Reply With Quote
Old   August 18, 2013, 12:00
Bruno Santos
Hi Anand,
What exactly do you want to know? The math part or the programming part?
UPDATE:
$ wmake
You need to install make; gcc and g++ are also necessary. On Ubuntu, to install them, you can simply run:
sudo apt-get install build-essential
Best regards,
Bruno
Old   August 19, 2013, 05:44
Anand Lobo
Excellent, successful compilation.
A bit on the programming. Although I wouldn't say no to a refresher on the math - aerodynamics isn't my main field of study.
There are no MRFZones files I can find in the tutorials for OpenFOAM 2.2.x, so I'm not entirely sure how to use it with my 2D AMI simulation. There's MRFProperties though - same idea?
Old   August 19, 2013, 12:41
Bruno Santos
Hi Anand,
I'm not much in the mood right now to spend 30 to 60 minutes writing down how this utility works. Nonetheless, here are some links I suggest you read, to learn some more on how to interpret C++ and OpenFOAM source code:
The AMI capability in OpenFOAM is meant be used with dynamic mesh motion.
As for using MRF, you don't need AMI, since it uses a stationary mesh; but you will need a cellZone for indicating which cells are assigned to the MRF zone.
The reference tutorials for each one are:
  • AMI: "incompressible/pimpleDyMFoam/propeller"
  • MRF: "multiphase/MRFInterFoam/mixerVessel2D"
If you study these two tutorials, you should be able to later find other similar tutorials.
Best regards,
Bruno
Old   August 20, 2013, 00:50
Anand Lobo
I'm not much in the mood right now to spend 30 to 60 minutes writing down how this utility works. Nonetheless, here are some links I suggest you read ...
Lol, no worries, I wouldn't ask for a blow-by-blow breakdown, just an overview. I'll take a look, although I find I learn more from other people's guidance rather than peering through reams of code.
I'm looking at the MRF tutorials already, and my rotating AMI simulation is up and running. It's how to combine the two that I'm trying to figure out, so I can figure out the torque in the rotating region.
Old   August 21, 2013, 10:42
Bruno Santos
Mmm... why not use the "forces" function object? It provides the vectorial forces and momentums for the desired patch list. I wrote some information on where you can find information about this on this post: http://www.cfd-online.com/Forums/ope...tml#post446397 post #6
Old   August 22, 2013, 01:07
Anand Lobo
... Good point, lol. Looks I have the forces enabled in my controlDict but I didn't see the output as it was hidden in a subfolder, and not directly readable by ParaView. Looks like I'll have to manually convert those outputs to CSV.
Edit: well, I think I've got it figured out. Found out the section of code dealing with the file output and modified that to look closer to CSV format.
mrfsimplefoam, openfoam 2.1, torque
Calculating Torque tripa58 CFX 1 October 28, 2010 18:10
Calculating torque beejois FLUENT 2 March 12, 2010 01:22
calculating torque shawn123 STAR-CCM+ 3 January 23, 2010 21:32
Calculating torque Andrew FLUENT 5 September 4, 2007 11:10
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
