[OpenFOAM] How to Plot Eddies in Paraview :) |
June 10, 2013, 17:00 |
Hasan K.J.
Hey All,
i am Trying to get eddies for LES case on my paraview in openFOAM - i switched the contours on !! no help and i dunno where to go what to do get the eddies like the ones i have attached in the image Please help Thanks for your time Hasan K.J |
June 11, 2013, 08:12 |
vortex detection criteria
Zoltan Hernadi
Dear Hasan,
It depends on the vortex detection criteria. You may try using Q utility to generate second invariant of the velocity gradient tensor and visualize a contour of this field. Other option is using Lambda2 utility. But there are other vortex detection criteria as well. I hope this helps. Zoltan |
June 12, 2013, 21:33 |
Where is Q utility and Lambda 2 utility
Hasan K.J.
Hey Zoltan,
I am not able to find these two utilities the Q utility and Lambda 2 utility ? - please can u tell where the option is in paraview ? - i searched i am not able to locate it Thanks Regards, Hasan K.J |
June 13, 2013, 01:19 |
Ehsan
Rep Power: 26 |
hi
Execute the commands in terminal.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
June 13, 2013, 02:25 |
Zoltan Hernadi
In addition to Ehsan's help, you might be interested in this list of OpenFOAM utilities:
http://openfoam.org/docs/user/standard-utilities.php |
June 13, 2013, 16:41 |
Ehsan
Rep Power: 26 |
Hi hasan
could you see the vortices?could you attach them? I used lambda2 and Q without sucess.not any vortices are displayed!
June 13, 2013, 16:49 |
Hasan K.J.
No... i havent tried it yet ? but does it actually make a difference if its LES or RAS case...?
June 13, 2013, 17:02 |
Ehsan
Rep Power: 26 |
i don't think it has a lot of effect on vortices.
what your opinion dear Zoltan?how could I set a contour for labda or Q?is the wide range normal in your opinion?
June 13, 2013, 20:04 |
Lambda2 error
Hasan K.J.
Hey guys,
My life is never simple and i will never get used to it - i typed Q and it worked fine with my case - then i typed Lambda2 and i get this error does any body know what this error means and whats causing it - and Ehsan if you manage to get the eddies please let me know Regards, Hasan K.J. and it works only for last time with some warning Create mesh for time = 10000 Time = 10000 Reading U --> FOAM Warning : From function eigenValues(const tensor&) in file primitives/Tensor/tensor/tensor.C at line 174 complex eigenvalues detected for tensor: (1902.57 7.65293e-07 -0.000402738 7.65293e-07 1902.57 3.34481e-05 -0.000402738 3.34481e-05 4.34386e-10) --> FOAM Warning : From function eigenValues(const tensor&) in file primitives/Tensor/tensor/tensor.C at line 174 complex eigenvalues detected for tensor: (1902.57 7.65152e-07 -0.000250995 7.65152e-07 1902.57 2.85284e-05 -0.000250995 2.85284e-05 1.62937e-09) --> FOAM Warning : From function eigenValues(const tensor&) in file primitives/Tensor/tensor/tensor.C at line 174 complex eigenvalues detected for tensor: (1902.57 7.65293e-07 0 7.65293e-07 1902.57 0 0 0 2.587e-09) Writing -Lambda2 End Create time Create mesh for time = 0 Time = 0 Reading U #0 Foam::error:rintStack(Foam::Ostream&) in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #2 in "/lib64/libc.so.6" #3 acos in "/lib64/libm.so.6" #4 Foam::eigenValues(Foam::Tensor<double> const&) in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #5 Foam::eigenValues(Foam::Field<Foam::Vector<double> >&, Foam::UList<Foam::Tensor<double> > const&) in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/lib/libOpenFOAM.so" #6 in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/bin/Lambda2" #7 in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/bin/Lambda2" #8 in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/bin/Lambda2" #9 in "/panfs/storage/local/non-commercial/OpenFOAM/OpenFOAM-SGISLES11-2.1.X_X8664_21JUNE12_REPO/OpenFOAM-2.1.x/platforms/linux64Gcc46DPOpt/bin/Lambda2" #10 __libc_start_main in "/lib64/libc.so.6" #11 at /usr/src/packages/BUILD/glibc-2.11.3/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception |
June 13, 2013, 20:42 |
No Luck
Hasan K.J.
Hey guys,
the maximum i can get to with my only working Q utility is this much i tried contours with the Q selected nothing works ? - if anybody manages to get it or know how to get it please help us thanks Regards, Hasan K.J |
June 14, 2013, 02:42 |
#11 |
Ehsan
Rep Power: 26 |
how should set contour settings for a good figure?
its a test case. whats the stages to see vortices contours? thanks.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. Last edited by immortality; June 16, 2013 at 11:57. |
June 16, 2013, 12:22 |
#12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
OK, using Ehsan's test case, here's what's going on: you are being blind-sighted by the maximum values. You need to change the scales down to lower values, such as [-200000, 200000], as shown in the 1st attached image. If you don't know how to change the scale, read this post: http://www.cfd-online.com/Forums/ope...tml#post429974 - post #2. As for contours, from the menu, choose "Filters -> Alphabetical -> Contour". Then configure as shown in the second image. Best regards, Bruno
December 2, 2013, 19:37 |
#13 |
hi, Alhasan
Have you solved the error with Lambda2? if so, please tell me how to solve it? thanks |
December 3, 2013, 09:16 |
#14 | |
Hasan K.J.
The problem i had was sorted when i put the right value for the Q criterion that i was trying to get on paraView - First you use the Command and get the Q or Lambda2 from openFOAM - then you paraView and select the contour botton and apply - then select the Lambda2 within the Contour dialogue box - then choose the right range or value, - if you dunno the right range play with the values till you get what you are looking for All the Best, Hasan K.J |
December 5, 2013, 19:47 |
#15 | |
[OpenFOAM] How to plot flow rate over time with Paraview | sekunda | ParaView | 17 | July 23, 2020 13:14 |
[OpenFOAM] Paraview: Plot over line only displays line for untranslated data | Illmatic | ParaView | 1 | January 13, 2020 11:42 |
Different results using sample utility vs Paraview 'Plot over line' tool | agarwa58 | OpenFOAM Post-Processing | 5 | March 20, 2016 08:57 |
[General] Paraview: plot over a certain value and add axis | nwpukaka | ParaView | 1 | May 16, 2014 16:01 |
[OpenFOAM] Plot of different variables using Paraview | subhkirti | ParaView | 0 | December 23, 2010 05:22 |
