calculate epsilon from RANS k-Omega simulation
Like Tree6Likes
  • 1 Post By CFD_Monkey
  • 5 Post By CFD_Monkey
Old   June 20, 2013, 06:07
Default calculate epsilon from RANS k-Omega simulation
CFD_Monkey is on a distinguished road
Hi FOAMers,
in order to get the epsilon value from a RANS simulation (kOmega, kOmegaSST respectively) I was searching the source code. This is what I've found in kOmegaSST.H:
00250         //- Return the turbulence kinetic energy dissipation rate
 00251         virtual tmp<volScalarField> epsilon() const
 00252         {
 00253             return tmp<volScalarField>
 00254             (
 00255                 new volScalarField
 00256                 (
 00257                     IOobject
 00258                     (
 00259                         "epsilon",
 00260                         mesh_.time().timeName(),
 00261                         mesh_
 00262                     ),
 00263                     betaStar_*k_*omega_,
 00264                     omega_.boundaryField().types()
 00265                 )
 00266             );
 00267         }
My question: How can I run this section to get epsilon (for e.g. in case of the reynoldsstresstensor it's just the command R)
Cheers
immortality likes this.
CFD_Monkey is offline   Reply With Quote
Old   June 27, 2013, 10:55
I don't know if this is the best way to get the epsilon value but it works!
1. create the directory ~/Openfoam/$USER-2.1.x/utilities/postProcessing/turbulence/
2. copy the attached files into.
3. run the command "wmake" from the epsilon directory
This will create the folders platforms/.../bin in the ~/Openfoam/$USER-2.1.x/ directory and compiles the epsilon.C file. The executive "epsilon" is created there and can be called by "epsilon" from any case directory.
Note: This should work for kOmega as well as for kOmegaSST. While the difference is simply a change of constants:
kOmega: epsilon=Cmu*k*omega
kOmegaSST: epsilon=betaStar*k*omega
Which is normally the same value: betaStar=Cmu=0.09
How to calculate torque from the simulation result sivakumar OpenFOAM Post-Processing 21 December 11, 2019 11:24
Unsteady RANS simulation of Jet in crossflow harshad88 FLUENT 0 June 2, 2013 13:29
epsilon and K blowing up. sivakumar OpenFOAM Running, Solving & CFD 1 October 25, 2012 04:50
Do RANS simulation overpredict maximum Cp? Sergio Rossi Main CFD Forum 0 May 15, 2007 09:23
RANS simulation prasat Main CFD Forum 0 June 4, 2003 11:04
