Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
pyFoamRedoPlot.py option 'show-window'
Old   July 18, 2013, 01:38
Default pyFoamRedoPlot.py option 'show-window'
Studi is on a distinguished road
Hello everybody!
As titled, I have a question about the 'show-window' option of pyFoamRedoPlot. I have expected several windows popping up due to this option, but nothing happens. I tried it on two different PCs (both Suse 12.2). Generally the command works fine (writes hardcopies, connects to server etc.). Am I expecting something wrong? I would like to have a quick overview of a simulation from another PC while the 'server' is running it. Are there any other ways to do this?
Thanks for any advice.
The command:
pyFoamRedoPlot.py --show-window --sleep-time=5 --server <server> <port>
The output:
Found 7 plots and 7 data sets
Adding line 1
Adding line 3
Adding line 2
Adding line 5
Adding line 4
Adding line 7
Adding line 6
Plotting 1 : linear
Plotting 3 : bounding No data - skipping
Plotting 2 : continuity
Plotting 5 : courant No data - skipping
Plotting 4 : iterations
Plotting 7 : execution
Plotting 6 : timestep No data - skipping
Studi is offline   Reply With Quote
Old   July 18, 2013, 05:40
Assistant Moderator
Bernhard Gschaider
Originally Posted by Studi View Post
Hello everybody!
The command:
The output:
Adding line 1
Adding line 3
Adding line 2
Adding line 5
Adding line 4
Adding line 7
Adding line 6
Plotting 1 : linear
  • Have a look at the directory: you should find some files with the ending PNG. Assignment: Google to find out what that data format could be
  • Use the utility with the option --help and wonder what '--show-window' could be about. Assignment: if option does not work as expected write a bug report
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 18, 2013, 05:56
Of course I did all this before writing here. As I said, there are hardcopies (PNG), if I want them to be there. And after consulting the utilities help I expected the plots to show up, what they didn't.
I just asked before writing a bug report, trying to avoid a developer spending useless time on things I misunderstood.
Regards
Old   July 22, 2013, 14:50
Assistant Moderator
Bernhard Gschaider
Regards
Sorry. Should have read the title of your posting before answering. Now I feel like Vader in the Star Wars Canteen ("Oh. I didn't realise")
Will look into the issue (saw you opened a ticket on the Manits. Thanks)
Old   July 23, 2013, 01:19
Never mind! I'm glad to help a little with this awesome project...
Regards
Error message: Insufficient Catalogue Size Paresh Jain CFX 32 February 3, 2021 03:37
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
forced to sticking of soot particle kmgraju CFX 0 November 27, 2012 09:08
