Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
reconstructPar does not work in interDyMFoam
Like Tree5Likes
  • 5 Post By banji
Old   August 9, 2013, 12:00
Default reconstructPar does not work in interDyMFoam
Anastasios
ageorg is on a distinguished road
Dear All,
I am trying to execute "reconstructPar" utillity in a 3d case that I had simulated in ItterDyMFoam decomposed in 16 parts (cores) and I get the following message:
z620@Z620:~/OpenFOAM/z620-2.2.1/run/MySimulations/3DBubbleRiseAndDetachment$ reconstructPar
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.1-57f3c3617a2d
Exec : reconstructPar
Date : Aug 09 2013
Time : 17:56:01
Host : "Z620"
PID : 3480
Case : /home/z620/OpenFOAM/z620-2.2.1/run/MySimulations/3DBubbleRiseAndDetachment
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Reconstructing fields for mesh region0
Time = 0.001
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/z620/OpenFOAM/z620-2.2.1/run/MySimulations/3DBubbleRiseAndDetachment/processor0/0.001/polyMesh/pointProcAddressing at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
Can somebody please advise me what to do?
Thank you very much in advance
ageorg
ageorg is offline   Reply With Quote
Old   August 28, 2013, 10:47
Andrea Ferrari
Andrea_85 is on a distinguished road
Did you solve the problem?
andrea
Andrea_85 is offline   Reply With Quote
Old   November 7, 2013, 07:47
Kostis
cosbergel is on a distinguished road
try recontstructParMesh
cosbergel is offline   Reply With Quote
Old   November 8, 2013, 01:29
idefix is on a distinguished road
exactly: you must use reconstructParMesh before you can use reconstructPar
look here:
http://www.cfd-online.com/Forums/ope...tpar-15-a.html
Sega posted a script for it:
Originally Posted by sega View Post
#!/bin/bash
timeList=$(ls processor0/ | awk '$1!="constant"');
for line in $timeList
do
    echo "Recontructing mesh for t = "$line" s";
    reconstructParMesh -time $line > logTmp;
    echo "Reconstructing fields for t = "$line" s";
    reconstructPar -time $line > logTmp;
    echo "";
done
rm logTmp;
Last edited by wyldckat; November 9, 2013 at 11:48. Reason: Added [CODE][/CODE] and fixed the quote
idefix is offline   Reply With Quote
Old   April 15, 2016, 13:25
Olabanji
banji is on a distinguished road
I am sure you must have found some solution some way, since this was posted a long time ago. I decided to just post mine just for anybody who runs into the same problem like me.
I use OpenFOAM-2.3.x. When you run a problem using AMR in parallel. To reconstruct, first open the system/controlDict file and change the entry for write format from "ascii" to "binary". Then do the following
1) run 'reconstructParMesh'
2) run 'reconstructPar'
This works with no problem in 2.3 version, not sure of the rest.
Cheers.
Originally Posted by ageorg View Post
Dear All,
Date : Aug 09 2013
Time : 17:56:01
Host : "Z620"
PID : 3480
nProcs : 1
Create time
Time = 0.001
cannot find file
FOAM exiting
ageorg
Last edited by banji; April 16, 2016 at 01:48. Reason: Need to add more information for clarity
banji is offline   Reply With Quote
Problems with reconstructPar after run interDyMFoam FG_HSRM OpenFOAM 3 December 13, 2011 11:16
InterDyMFoam with GGI sebastianweiper OpenFOAM Running, Solving & CFD 2 September 18, 2009 03:43
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
