Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
how can see mu(laminar) like mut(turbulent)?
Like Tree2Likes
  • 1 Post By fportela
  • 1 Post By wyldckat
Old   September 13, 2013, 07:37
Default how can see mu(laminar) like mut(turbulent)?
immortality's Avatar
Ehsan
immortality is on a distinguished road
is it possible to see laminar mu(viscosity) after run by any postProcessing utility?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   September 13, 2013, 07:44
Bernhard
Bernhard is on a distinguished road
Can you give more details? If laminar viscosity is constant, it doesn't make a lot of sense, right?
Bernhard is offline   Reply With Quote
Old   September 13, 2013, 10:36
Ehsan
in some thermophysical models like JANAF it varies with T for perfect gases.
Old   September 13, 2013, 11:21
Felipe Alves Portela
fportela is on a distinguished road
I'm not sure if there is any utility available to do that, but it shouldn't be very hard to implement.
Just create an IOobject for the viscosity, then go through your time steps and store it, is this what you want?
fportela is offline   Reply With Quote
Old   September 13, 2013, 11:31
Ehsan
yes seems be simple to do it before run,but my runs have finished and thought may there be a postProcessing utility,not important,thanks for your consideration dear Felipe.
Old   September 13, 2013, 12:05
You might want to look at the postChannel utility, just as a reference. This utility computes some fields for each of the time steps and prints out some other things (also for each time step), which I believe is along the same lines of what you are trying to do!
immortality likes this.
Old   September 15, 2013, 16:04
Retired Super Moderator
Bruno Santos
Greetings to all!
@Ehsan: This one seems to be very complicated. At least if we look directly at the thermodynamics part of OpenFOAM.
The problem here is that "nu" is not present in the thermodynamics part of OpenFOAM. It's only present in the transport-related libraries, such as the one for laminar flow, the multiphase flows and the turbulence flows.
The best I can find is the source code provided here: http://repo.or.cz/w/OpenFOAM-2.2.x.g...eclet/Peclet.C - it shows a few ways on how to get the "nuEff", but neither one seem to depend on thermodynamics.
Wait... no no no... it's a compressible model, you don't look for the "nu" directly, you look for "mu" and "rho" and calculate from there!
Arg... I read incorrectly the question You want "mu"!!! I'm tired already and the work week hasn't even started...
In theory, it should be as simple as adding something like this to either one of the other applications you sent me:
            Info<< "    Calculating mu" << endl;
            volScalarField mu
                IOobject
                    "mu",
                    runTime.timeName(),
                    mesh,
                    IOobject::NO_READ
                thermo.mu()
