Function Object cloudInfo
Old   March 6, 2014, 06:42
Default Function Object cloudInfo
Mentalo is on a distinguished road
if have seen that since OF v2.2.0 a functionality called cloudInfo was implemented. Im very interested in using this tool , but i have no idea of how this is done. Do i have to write a custom pre-processor to use this utility? Help would be appreciated. Thanks in advance.
http://www.openfoam.org/version2.2.0...processing.php
Regards
Mentalo
Mentalo is offline   Reply With Quote
Old   March 7, 2014, 03:06
Ok now I got it running. But there ist still a strange problem. On a singel core, without decomposing the case, the cloudInfo object works perfectly fine. But by starting the run on MPI, I get an error message:
faceSource cuttingplane_average output:
    areaAverage(sampledSurface) for p = 99991.3
    areaAverage(sampledSurface) for U = (7.71105e-05 -6.53393e-06 20.1689)
    areaAverage(sampledSurface) for T = 280.929
    areaAverage(sampledSurface) for rho = 1.23573
    areaAverage(sampledSurface) for C7H16 = 5.37203e-98
[philipp-Home:3137] *** An error occurred in MPI_Recv
[philipp-Home:3137] *** on communicator MPI_COMM_WORLD
[philipp-Home:3137] *** MPI_ERR_TRUNCATE: message truncated
[philipp-Home:3137] *** MPI_ERRORS_ARE_FATAL: your MPI job will now abort
mpirun has exited due to process rank 0 with PID 3137 on
node philipp-Home exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
The faceSource object works perfectly fine, either runing single or multi core.
I tried to execute the post processing, after reconstructing the case, via execFlowFunctionObjects, but then OpenFoam gets stuck saying:
Time = 0
    Reading phi
--> FOAM Warning :
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/philipp/cfd/OF_22x/full_spray_SP1_5/0/phi at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 73.
Time = 0.0005
    Reading phi
    Reading U
    Reading p
No finite volume options present
Selecting thermodynamics package
    type            hePsiThermo;
    mixture         reactingMixture;
    transport       sutherland;
    thermo          janaf;
    energy          sensibleEnthalpy;
    equationOfState perfectGas;
    specie          specie;
Selecting chemistryReader chemkinReader
Reading CHEMKIN thermo data in new file format
and it won't continue
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 10:20
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
