March 4, 2014, 05:08 |
Sample at a single point?
Olie
Rep Power: 12 |
Apologies for what seems a trivial question, but how can I sample at a SINGLE POINT? I've managed to sample across lines, but I just want to sample at a single coordinate, (x,y,z), and have tried using 'cloud' and other things but can't get it to work!
Thanks in advance. Olie |
March 4, 2014, 05:20 |
try probeLocations utility. Though all the values at different time steps will be in a single file. |
March 4, 2014, 05:37 |
Olie
Rep Power: 12 |
Thanks this looks like what I'm after - is this something that I need to set up before running the simulation (there seems to be a lot of talk about it being related to the controlDict when I googled it), or something I can use AFTERWARDS like the rest of the sampleDict utilities? Thanks, Olie |
March 4, 2014, 05:42 |
if you'd like to do run-time probing, you put description of the probes into controlDict, if you'd like to do probing after simulation, you create probesDict file (see example in $FOAM_APP/utilities/postProcessing/sampling/probeLocations), put it in the system folder and run probeLocations. |
March 4, 2014, 05:50 |
Olie
Rep Power: 12 |
Oh brilliant, thanks.
point, sample |
Single v.s. double precision | Confused | CFX | 15 | November 10, 2016 04:42 |
[Commercial meshers] Converting fluent mesh to foam | sivakumar | OpenFOAM Meshing & Mesh Conversion | 11 | April 30, 2013 09:29 |
[Other] [Gridgen] boundary condition for single point | yidongxia | OpenFOAM Meshing & Mesh Conversion | 2 | November 20, 2012 10:51 |
Sample issues | MikePo | OpenFOAM Post-Processing | 1 | February 7, 2010 19:20 |
CFX Post: Problems with moving point cloud for changing time steps | spatialtime | CFX | 0 | December 7, 2009 04:56 |
