Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
coded function object and field average
Like Tree2Likes
  • 1 Post By wyldckat
  • 1 Post By fabian_roesler
Old   June 27, 2014, 09:53
Default coded function object and field average
Matthias Walter
matthias is on a distinguished road
Hi folks,
I'm using the coded function object to create and calculate the field epsilon
   epsilonAverage
        functionObjectLibs ("libutilityFunctionObjects.so");
        type coded;
        redirectType average1;
        outputControl timeStep;
        code
            volScalarField epsilon
                IOobject
                    "epsilon",
                    mesh().time().timeName(),
                    mesh(),
                    IOobject::NO_READ,
                    IOobject::AUTO_WRITE
                2*mesh().lookupObject<volScalarField>("nu")*magSqr(symm(fvc::grad(mesh().lookupObject<volVectorField>("U"))))
            //epsilon.write();
When I call the fieldAverage function object and apply the averaging to epsilon, it isn't known since the field epsilon is not registered globally but only within the code directive.
So is it possible to use the fieldAverage function object for this purpose?
(Of course I can implement the code into the solver directly but using the coded function object I must not change the solver)
Best regards
Matthias
matthias is offline   Reply With Quote
Old   June 28, 2014, 15:42
Retired Super Moderator
Bruno Santos
Greetings Matthias,
I'm not certain I understand the problem you're describing, but my understanding is that you're using something like the utility execFlowFunctionObjects and using that function object to calculate the average of epsilon field!? The part I'm not certain is why you're using a coded function object...
OK, there are two possible answers, from what I can figure out from your question:
  1. Use the option "-noFlow" when calling execFlowFunctionObjects: http://openfoamwiki.net/index.php/Ex...unctionObjects
  2. Or use another function object to load up the fields you need (before the one you're using):
        readFields
            functionObjectLibs ( "libfieldFunctionObjects.so" );
            type readFields;
            fields (p U epsilon);
Best regards,
Bruno
maetlg likes this.
Old   June 30, 2014, 04:41
Matthias Walter
Hi Bruno,
actually I don't use the execFlowFunctionObjects. My intention was to calculate the dissipation field (epsilon) on-the-fly without modifying the solver.
I can calculate the epsilon field in system/controlDict using the coded function object but how does the averaging work? After the coded function object has been finished the epsilon field can be written to disk but it is not registered! If you call the averaging function object after coded function object it won't find a field named epsilon.
I will have a look at execFlowFunctionObjects if it will do the job.
Best regards
Matthias
Old   June 30, 2014, 04:52
Default create registered object during runtime using functionobject
Fabian Roesler
fabian_roesler is on a distinguished road
Hi Matthias
Have a look into this thread:
http://www.cfd-online.com/Forums/ope...ionobject.html
In post #12 (http://www.cfd-online.com/Forums/ope...tml#post387459) Eelco explains the solution to his problem using functionobjects.
Cheers
Fabian
wyldckat likes this.
fabian_roesler is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
How to use DESModelRegions function object hakonbar OpenFOAM Running, Solving & CFD 33 April 21, 2019 06:17
Problem with using function object to compute Nu number in parallel. feldy77 OpenFOAM Programming & Development 0 September 9, 2011 19:17
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
