November 5, 2014, 09:05 |
OpenFOAM and Abaqus
wojtek
Hello Foamers!
I have a question concerning cooperation OpenFoam 2.3.0 with Abaqus 6.12. I would like to try make turbine blade calculation in OpenFoam and create some pressure surfaces. Is it possible to transfer the results from OpenFOAM to Abaqus to make stress analysis for example checking vibration? Do I need some additional software? regards Wojtek |
November 5, 2014, 12:28 |
Marco A. Turcios
Rep Power: 28 |
Hi Wojtek,
There is in built in tool that will convert OpenFOAM data to ABAQUS. However, the data format is pretty easy to work with, so it shouldn't be too hard to write a conversion program/script. You would need to map the data from OF (pressure, force) on the nodes/faces into the ABAQUS format. Good luck! |
November 8, 2014, 16:29 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer/tip: The solidMechanics toolkit has a foamMeshToAbaqus utility, although as the name indicates, it only converts the mesh to Abaqus' format.
November 10, 2014, 08:18 |
are you looking for s.th like http://www.mpcci.de/mpcci-software.html http://www.mpcci.de/mpcci-descriptio...e-adapter.html? |
openfoam 2.3.0 abaqus |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
[Other] vtk mesh or Abaqus mesh to OpenFOAM | bigphil | OpenFOAM Meshing & Mesh Conversion | 27 | November 23, 2015 17:31 |
Coupling OpenFOAM with Abaqus | skuznet | OpenFOAM Programming & Development | 4 | January 21, 2014 10:56 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
Coupling OpenFOAM with Abaqus through MpCCI | kvick | OpenFOAM Running, Solving & CFD | 6 | July 27, 2010 03:00 |
