February 25, 2015, 08:57 |
Circular averaging of wallheatflux
Hello foamers,
I’m simulating a pipe with research interest on heat transfer. I calculated the wallheatflux with the appropriate tool from OF. What i need now is the circular average of the wallheatflux in every position along the pipe axis. I tried to use the sample dict for this purpose. 1. option here was to to extract the wallheatflux for the whole boundary patch "walls" and then manipulate that list e.g. in matlab or so. But this is not so easy and the list always depends on the grid. So for several grid that seems not so appropriate for me (but it works) 2. option I had was to use the set "circle" in the sample dict. But there I had the problem that not all points were extracted (see this thread http://www.cfd-online.com/Forums/ope...tml#post533060 ) And further i think because of the interpolation, the extracted values are a bit smaller than the exact values on the boundary patch. (I compared these values to those from matlab and indeed they were smaller) No more options i could imagine at the moment. So the questions is are there other possibilities to do a circular averaging of the wallheatfluxes in OF postprocessing? Thanks in advance! Daniel |
September 13, 2019, 09:50 |
#2 | |
George Sof
Rep Power: 6 |
Hello Daniel, i am sorry to recover an old thread but did you manage to find another solution to your problem? I am facing the same averaging problem right now as you, but for velocity along pipe axis. Thank you in advance! |
Starting field averaging using libFunctionObject after certain time | eelcovv | OpenFOAM Programming & Development | 25 | December 7, 2015 22:28 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
When to use mass flow averaging | cspectre | CFX | 2 | December 6, 2009 05:30 |
Rotational averaging in a circular container/mesh | Shany | OpenFOAM Running, Solving & CFD | 1 | July 6, 2009 05:25 |
