July 25, 2022, 06:30 |
Can't get residual plot for K and Omega
yasmine
Rep Power: 3 |
Hello foamers,
I am making a simulation using the komega sst turbulence model and i am monitoring the residuals in real time but unfortunately i only get plots for the P Ux and Uy but cant get residual plots for the K and Omega ?! is there any suggestiong about how to resolve this issue?!! |
July 25, 2022, 08:16 |
Yann
Rep Power: 26 |
Hi Yasmine,
Can you elaborate? How do you monitor the residuals, what functions are you using, which solver, etc... Thanks, Yann |
July 25, 2022, 08:52 |
#3 | |
yasmine
Rep Power: 3 |
Thank you for the Reply , in order to plot the residuals i have inserted this line in the controlDict File the flowing line functions { #includeFunc residuals } and I added a residual file in system. When I execute my calculation with ( mpirun -np 12 SRFSimpleFoam -parallel > log ) the calculations run correctly in log without any problem but in the residuals.dat file in the post processing folder there are only the velocity and pressure values. also when I plot the residuals I only have the velocity and pressure plots (w and k are missing) I could send you this by email if you want to make it clearer (I don't know how to put the files here) |
July 25, 2022, 09:02 |
Yann
Rep Power: 26 |
Can you just paste the content of your system/residuals file here ?
You can use the [CODE] tag (paste between the following tags): [CODE][/CODE ] Thanks, Yann |
July 25, 2022, 09:10 |
yasmine
Rep Power: 3 |
my residual file in system :
[CODE]/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Web: www.OpenFOAM.org \\/ M anipulation | ------------------------------------------------------------------------------- Description For specified fields, writes out the initial residuals for the first solution of each time step; for non-scalar fields (e.g. vectors), writes the largest of the residuals for each component (e.g. x, y, z). \*---------------------------------------------------------------------------*/ #includeEtc "caseDicts/postProcessing/numerical/residuals.cfg" fields (p U k omega); // ************************************************** *********************** // [/CODE ] |
July 25, 2022, 09:16 |
yasmine
Rep Power: 3 |
in case/postProcessing/residuals/0/ :
# Residuals # Time p Ux Uy Uz k omega 1 1.000000e+00 N/A 1.000000e+00 7.381090e-03 2 1.184740e-01 N/A 3.004260e-01 9.900590e-03 3 1.372570e-01 N/A 1.864050e-01 2.488720e-03 4 5.901410e-02 N/A 1.588650e-01 5.401030e-04 5 8.814780e-02 N/A 1.479080e-01 1.200040e-04 6 1.253310e-01 N/A 1.418400e-01 3.845520e-05 7 2.565160e-01 N/A 1.423450e-01 1.849330e-05 8 4.336510e-01 N/A 1.497910e-01 1.253860e-05 9 4.601830e-01 N/A 1.510710e-01 1.025730e-05 10 1.930540e-01 N/A 1.447380e-01 8.981750e-06 11 1.148540e-01 N/A 1.430770e-01 8.430300e-06 12 9.624520e-02 N/A 1.441970e-01 8.416790e-06 13 1.051520e-01 N/A 1.431350e-01 8.249120e-06 14 1.067250e-01 N/A 1.400700e-01 8.190930e-06 15 1.124230e-01 N/A 1.370520e-01 8.239140e-06 16 1.127760e-01 N/A 1.340960e-01 8.434510e-06 17 9.872760e-02 N/A 1.317960e-01 8.502050e-06 18 8.100470e-02 N/A 1.300360e-01 8.686630e-06 19 6.849960e-02 N/A 1.288510e-01 8.985640e-06 20 6.633530e-02 N/A 1.272620e-01 9.242020e-06 |
July 25, 2022, 09:20 |
Yann
Rep Power: 26 |
Thanks, in your controlDict, try replacing #includeFunc by #include:
functions { #include residuals } Yann |
July 25, 2022, 09:26 |
yasmine
Rep Power: 3 |
unfortunately it doesn't work, I get this as an error message:
--> FOAM FATAL IO ERROR: wrong token type - expected string, found on line 52 the word 'residuals' file: C:/Users/yasmine/AppData/Roaming/BLUECF~2/ofuser-of8/run/mixer/system/controlDict at line 52. at line 52 i have : #include residuals |
July 25, 2022, 09:32 |
#9 |
Yann
Rep Power: 26 |
My bad!
Just to be sure before going further, could you please post the log file of your run? (you can attach a file with your message, trim it down to the beginning of the log file up to the few first iterations if it is too big to upload) |
July 25, 2022, 09:37 |
#10 |
yasmine
Rep Power: 3 |
my log file (I put the beginning and the end) :
Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: no convergence criteria found. Calculations will run for 2000 steps. Reading field p Reading field Urel Reading/calculating face flux field phi AMI: Creating addressing and weights between 5869 source faces and 5869 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 1, 1 Creating SRF model Selecting SRFModel rpm Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; alphaK1 0.85; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.856; gamma1 0.555556; gamma2 0.44; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Urelx, Initial residual = 1, Final residual = 0.0126975, No Iterations 4 smoothSolver: Solving for Urely, Initial residual = 1, Final residual = 0.0141798, No Iterations 4 smoothSolver: Solving for Urelz, Initial residual = 1, Final residual = 0.0201171, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0450792, No Iterations 4 GAMG: Solving for p, Initial residual = 0.0416938, Final residual = 0.00051409, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00741679, Final residual = 0.00024247, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00249148, Final residual = 8.94275e-05, No Iterations 2 time step continuity errors : sum local = 166.617, global = 15.1947, cumulative = 15.1947 smoothSolver: Solving for omega, Initial residual = 0.00738109, Final residual = 8.81856e-05, No Iterations 2 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0100352, No Iterations 2 ExecutionTime = 1.49 s ClockTime = 1 s Time = 2 smoothSolver: Solving for Urelx, Initial residual = 0.131829, Final residual = 0.00124024, No Iterations 4 smoothSolver: Solving for Urely, Initial residual = 0.287553, Final residual = 0.0028456, No Iterations 4 smoothSolver: Solving for Urelz, Initial residual = 0.318563, Final residual = 0.00175222, No Iterations 4 GAMG: Solving for p, Initial residual = 0.118474, Final residual = 0.00328084, No Iterations 5 GAMG: Solving for p, Initial residual = 0.0318544, Final residual = 0.00046694, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00571584, Final residual = 0.000205005, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00190701, Final residual = 7.79746e-05, No Iterations 2 time step continuity errors : sum local = 192.875, global = 18.9204, cumulative = 34.1152 smoothSolver: Solving for omega, Initial residual = 0.00990059, Final residual = 3.02477e-06, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.300426, Final residual = 0.0090328, No Iterations 2 ExecutionTime = 2.22 s ClockTime = 2 s Time = 3 smoothSolver: Solving for Urelx, Initial residual = 0.124796, Final residual = 0.00134026, No Iterations 4 smoothSolver: Solving for Urely, Initial residual = 0.183014, Final residual = 0.00127576, No Iterations 4 smoothSolver: Solving for Urelz, Initial residual = 0.291652, Final residual = 0.00179695, No Iterations 4 GAMG: Solving for p, Initial residual = 0.137257, Final residual = 0.00501436, No Iterations 4 GAMG: Solving for p, Initial residual = 0.0304781, Final residual = 0.000679854, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00568039, Final residual = 0.000260231, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00194214, Final residual = 4.64146e-05, No Iterations 3 time step continuity errors : sum local = 75.7742, global = 9.78391, cumulative = 43.8991 smoothSolver: Solving for omega, Initial residual = 0.00248872, Final residual = 2.61873e-06, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.186405, Final residual = 0.00884514, No Iterations 2 ExecutionTime = 2.97 s ClockTime = 3 s Time = 4 smoothSolver: Solving for Urelx, Initial residual = 0.23103, Final residual = 0.00287752, No Iterations 4 smoothSolver: Solving for Urely, Initial residual = 0.220433, Final residual = 0.00220461, No Iterations 4 smoothSolver: Solving for Urelz, Initial residual = 0.251165, Final residual = 0.00243047, No Iterations 4 GAMG: Solving for p, Initial residual = 0.0590141, Final residual = 0.00282732, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0143316, Final residual = 0.000468573, No Iterations 3 GAMG: Solving for p, Initial residual = 0.00498702, Final residual = 0.000187188, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00127501, Final residual = 3.57821e-05, No Iterations 3 time step continuity errors : sum local = 32.8889, global = -2.06978, cumulative = 41.8293 smoothSolver: Solving for omega, Initial residual = 0.000540103, Final residual = 2.41478e-06, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.158865, Final residual = 0.0112241, No Iterations 2 ExecutionTime = 3.68 s ClockTime = 4 s Time = 5 smoothSolver: Solving for Urelx, Initial residual = 0.203791, Final residual = 0.00250987, No Iterations 4 smoothSolver: Solving for Urely, Initial residual = 0.196476, Final residual = 0.00221819, No Iterations 4 smoothSolver: Solving for Urelz, Initial residual = 0.18284, Final residual = 0.00204569, No Iterations 4 GAMG: Solving for p, Initial residual = 0.0881478, Final residual = 0.00234285, No Iterations 4 GAMG: Solving for p, Initial residual = 0.130595, Final residual = 0.00237015, No Iterations 2 GAMG: Solving for p, Initial residual = 0.0210733, Final residual = 0.00089486, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00622934, Final residual = 0.000152093, No Iterations 3 time step continuity errors : sum local = 45.3095, global = -1.76439, cumulative = 40.0649 smoothSolver: Solving for omega, Initial residual = 0.000120004, Final residual = 1.8535e-06, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.147908, Final residual = 0.0120588, No Iterations 2 ExecutionTime = 4.41 s ClockTime = 4 s . . . . . . . . . Time = 1998 smoothSolver: Solving for Urelx, Initial residual = 0.00503808, Final residual = 6.27413e-05, No Iterations 4 smoothSolver: Solving for Urely, Initial residual = 0.00198169, Final residual = 2.4672e-05, No Iterations 4 smoothSolver: Solving for Urelz, Initial residual = 0.00322746, Final residual = 4.1753e-05, No Iterations 4 GAMG: Solving for p, Initial residual = 0.00672841, Final residual = 0.00024438, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00144828, Final residual = 3.86989e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.000475463, Final residual = 1.9264e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.000141943, Final residual = 5.013e-06, No Iterations 3 time step continuity errors : sum local = 0.351212, global = -0.00258018, cumulative = 8.82405 smoothSolver: Solving for omega, Initial residual = 2.12626e-06, Final residual = 1.59701e-07, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.00264075, Final residual = 2.91221e-05, No Iterations 4 ExecutionTime = 1422.87 s ClockTime = 1439 s Time = 1999 smoothSolver: Solving for Urelx, Initial residual = 0.00503523, Final residual = 6.25361e-05, No Iterations 4 smoothSolver: Solving for Urely, Initial residual = 0.00198526, Final residual = 2.47469e-05, No Iterations 4 smoothSolver: Solving for Urelz, Initial residual = 0.00323853, Final residual = 4.20185e-05, No Iterations 4 GAMG: Solving for p, Initial residual = 0.00672002, Final residual = 0.000243346, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00145101, Final residual = 3.90021e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.000484619, Final residual = 1.99894e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.000143845, Final residual = 5.00554e-06, No Iterations 3 time step continuity errors : sum local = 0.351595, global = -0.0125304, cumulative = 8.81152 smoothSolver: Solving for omega, Initial residual = 2.11238e-06, Final residual = 1.59213e-07, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.00266684, Final residual = 2.90942e-05, No Iterations 4 ExecutionTime = 1423.58 s ClockTime = 1439 s Time = 2000 smoothSolver: Solving for Urelx, Initial residual = 0.00502815, Final residual = 6.23425e-05, No Iterations 4 smoothSolver: Solving for Urely, Initial residual = 0.001989, Final residual = 2.48424e-05, No Iterations 4 smoothSolver: Solving for Urelz, Initial residual = 0.00324989, Final residual = 4.22898e-05, No Iterations 4 GAMG: Solving for p, Initial residual = 0.00674416, Final residual = 0.000245853, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00145269, Final residual = 7.18713e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.000451705, Final residual = 1.6493e-05, No Iterations 3 GAMG: Solving for p, Initial residual = 0.000198452, Final residual = 6.16087e-06, No Iterations 2 time step continuity errors : sum local = 0.433841, global = -0.0256793, cumulative = 8.78584 smoothSolver: Solving for omega, Initial residual = 2.10729e-06, Final residual = 1.59279e-07, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.00266866, Final residual = 2.90817e-05, No Iterations 4 ExecutionTime = 1425.05 s ClockTime = 1442 s End Finalising parallel run |
July 25, 2022, 09:46 |
#11 |
Yann
Rep Power: 26 |
Thanks!
You are actually correctly getting the residuals for p, k and omega. Check the values reported in case/postProcessing/residuals/0/, the last 2 columns correspond to the initial residuals reported in the log file for k and omega, as expected. Your problem is actually related to the velocity field : SFRSimpleFoam solves the relative velocity Urel instead of U, but in your residuals file you are requesting residuals on p, U, k and omega. This is why you get a N/A column for the velocity. Try something like this, I guess it should work: Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Web: www.OpenFOAM.org \\/ M anipulation | ------------------------------------------------------------------------------- Description For specified fields, writes out the initial residuals for the first solution of each time step; for non-scalar fields (e.g. vectors), writes the largest of the residuals for each component (e.g. x, y, z). \*---------------------------------------------------------------------------*/ #includeEtc "caseDicts/postProcessing/numerical/residuals.cfg" fields (p Urel k omega); // ************************************************************************* // |
July 25, 2022, 10:02 |
#12 |
yasmine
Rep Power: 3 |
it worked! thank you so much Yann for your help and your time.
you have really saved me! |
Help sought on axial compressor simulation | jyotir | OpenFOAM Running, Solving & CFD | 0 | November 17, 2021 10:49 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
decompose dependent solution | arionfard | OpenFOAM | 3 | December 10, 2018 09:36 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
