November 18, 2023, 04:36 |
Showing solid format in paraview
Saeed Jamshidi
Rep Power: 7 |
Hello Foamers,
I would like to know how can I show an object in paraview. For example, see attached file which ellipse is hollow. I wanna see it in solid format in paraview. Thank you for your help 🙏. |
November 20, 2023, 07:21 |
RT
Rep Power: 6 |
Hello Saeed,
if I correctly understood, you would like to see the surface without grid lines, right? If yes, then you should choose 'Surface' instead of 'Surface with Edges' in the 2nd row of buttons. |
November 20, 2023, 07:29 |
Saeed Jamshidi
Rep Power: 7 |
Thank you for your response.
I got my answer finally, if I load cad file too I can see it. But in the case that object moves along time how can I show the the solid ? |
November 20, 2023, 07:43 |
Rep Power: 12 |
after paraFoam while loading selection choose inter mesh and also your object name, apply
then at menu choose filters > alphabetical > extract block, choose your solid from the left pane and apply, that's it. |
November 20, 2023, 08:19 |
Saeed Jamshidi
Rep Power: 7 |
Thank you that's it.
[OpenFOAM] ParaView only Showing OpenFOAM Case in Bottom Corner of Screen | Last123 | ParaView | 0 | November 6, 2023 21:18 |
[General] Question about VTK Format, Time and ParaView | ngj | ParaView | 8 | August 9, 2022 09:29 |
[General] How to open ".npy" file or convert ".npy" file to Paraview format? | sunagra27 | ParaView | 0 | August 14, 2020 05:29 |
[General] Paraview data format conversion from vtk to parallel prog data format. | odho | ParaView | 0 | September 20, 2016 07:01 |
[OpenFOAM] Problem showing flow around propeller in Paraview | orkavic | ParaView | 1 | December 25, 2013 11:02 |
