Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Showing solid format in paraview
Like Tree2Likes
  • 1 Post By Ryôzanpaku Tiger
  • 1 Post By mzzmrt
Old   November 18, 2023, 04:36
Default Showing solid format in paraview
Saeed Jamshidi
saeed jamshidi is on a distinguished road
Hello Foamers,
I would like to know how can I show an object in paraview. For example, see attached file which ellipse is hollow. I wanna see it in solid format in paraview.
Thank you for your help 🙏.
saeed jamshidi is offline   Reply With Quote
Old   November 20, 2023, 07:21
RT
Ryôzanpaku Tiger is on a distinguished road
Hello Saeed,
if I correctly understood, you would like to see the surface without grid lines, right? If yes, then you should choose 'Surface' instead of 'Surface with Edges' in the 2nd row of buttons.
saeed jamshidi likes this.
Ryôzanpaku Tiger is offline   Reply With Quote
Old   November 20, 2023, 07:29
Saeed Jamshidi
Thank you for your response.
I got my answer finally, if I load cad file too I can see it.
But in the case that object moves along time how can I show the the solid ?
Old   November 20, 2023, 07:43
mzzmrt is on a distinguished road
after paraFoam while loading selection choose inter mesh and also your object name, apply
then at menu choose filters > alphabetical > extract block,
choose your solid from the left pane and apply, that's it.
mzzmrt is offline   Reply With Quote
Old   November 20, 2023, 08:19
Saeed Jamshidi
Thank you that's it.
[OpenFOAM] ParaView only Showing OpenFOAM Case in Bottom Corner of Screen Last123 ParaView 0 November 6, 2023 21:18
[General] Question about VTK Format, Time and ParaView ngj ParaView 8 August 9, 2022 09:29
[General] How to open ".npy" file or convert ".npy" file to Paraview format? sunagra27 ParaView 0 August 14, 2020 05:29
[General] Paraview data format conversion from vtk to parallel prog data format. odho ParaView 0 September 20, 2016 07:01
[OpenFOAM] Problem showing flow around propeller in Paraview orkavic ParaView 1 December 25, 2013 11:02
