Home > Forums > Visualization & Post-Processing Software > ParaView
[OpenFOAM] Paraview Pciture Generation
Old   September 7, 2016, 04:19
Default Paraview Pciture Generation
Aravind Krishnamoorthi
Aravind_Krish is on a distinguished road
Send a message via Skype™ to Aravind_Krish
Hi i am using Paraview 4.4.0 to generate pictures for the mixture formation in a engine.
I have many time steps form openFoam calculation eg. 384 383.1 383.2 383.3.......384.
Using trace option i generated a python script to generate the pictures.
But during picture generation i do not need pictures to be generated at all time steps but only for 383 and 384.
I am attaching the code here..
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
paraview.simple._DisableFirstRenderCameraReset()
# create a new 'OpenFOAMReader'
casefoam = OpenFOAMReader(FileName='/usr2/tmp/Krishnamoorthi/case0383/case.foam')
casefoam.CaseType = 'Decomposed Case'
casefoam.MeshRegions = ['internalMesh', 'lagrangian/defaultCloud']
casefoam.CellArrays = ['CO', 'CO2', 'Chi', 'EqT', 'H', 'H2', 'H2O', 'N', 'N2', 'NO', 'O', 'O2', 'OH', 'RGA', 'RGA_inl', 'RGA_out', 'T', 'T_tmp', 'U', 'Ydefault', 'Ytf', 'Yto2', 'Z', 'Z2', 'alphat', 'cellMotionU', 'dRoHR', 'dropNum', 'dropVol', 'epsilon', 'fuel', 'k', 'liquidFrom0', 'liquidFrom1', 'liquidFrom2', 'liquidFrom3', 'liquidFrom4', 'meanDropMass', 'meanDropTemp', 'meanTheta', 'meanTheta0', 'meanURel', 'mut', 'omega', 'p', 'p_tmp', 'reactFuel', 'rho', 'voidFrac']
casefoam.LagrangianArrays = ['BY', 'T', 'Tboil', 'U', 'Uturb', 'Weber', 'ct', 'ctRT', 'd', 'd0', 'deltaD', 'dropletMass', 'fuel', 'fuels', 'injector', 'lifeTime', 'liquidCore', 'm', 'ms', 'n', 'origId', 'origProcId', 'peps', 'pk', 'rBubble', 'rBubbleDot', 'secondKHindex', 'tTurb', 'y', 'yDot']
# get animation scene
animationScene1 = GetAnimationScene()
# update animation scene based on data timesteps
animationScene1.UpdateAnimationUsingDataTimeSteps( )
# get active view
renderView1 = GetActiveViewOrCreate('RenderView')
# uncomment following to set a specific view size
# renderView1.ViewSize = [1499, 906]
# show data in view
casefoamDisplay = Show(casefoam, renderView1)
# trace defaults for the display properties.
casefoamDisplay.ColorArrayName = [None, '']
# reset view to fit data
renderView1.ResetCamera()
# set scalar coloring
ColorBy(casefoamDisplay, ('FIELD', 'vtkBlockColors'))
# show color bar/color legend
casefoamDisplay.SetScalarBarVisibility(renderView1 , True)
# get color transfer function/color map for 'vtkBlockColors'
vtkBlockColorsLUT = GetColorTransferFunction('vtkBlockColors')
# get opacity transfer function/opacity map for 'vtkBlockColors'
vtkBlockColorsPWF = GetOpacityTransferFunction('vtkBlockColors')
# create a new 'Slice'
slice1 = Slice(Input=casefoam)
slice1.SliceType = 'Plane'
slice1.SliceOffsetValues = [0.0]
# init the 'Plane' selected for 'SliceType'
slice1.SliceType.Origin = [0.0, -0.037722447887063026, 0.02939213067293167]
# toggle 3D widget visibility (only when running from the GUI)
Hide3DWidgets(proxy=slice1)
# get color transfer function/color map for 'p'
pLUT = GetColorTransferFunction('p')
# show data in view
slice1Display = Show(slice1, renderView1)
slice1Display.ColorArrayName = ['POINTS', 'p']
slice1Display.LookupTable = pLUT
# hide data in view
Hide(casefoam, renderView1)
slice1Display.SetScalarBarVisibility(renderView1, True)
# get opacity transfer function/opacity map for 'p'
pPWF = GetOpacityTransferFunction('p')
ColorBy(slice1Display, ('POINTS', 'RGA'))
# rescale color and/or opacity maps used to include current data range
slice1Display.RescaleTransferFunctionToDataRange(T rue)
# get color transfer function/color map for 'RGA'
rGALUT = GetColorTransferFunction('RGA')
# get opacity transfer function/opacity map for 'RGA'
rGAPWF = GetOpacityTransferFunction('RGA')
# current camera placement for renderView1
renderView1.CameraPosition = [0.3823356101683453, -0.037722447887063026, 0.02939213067293167]
renderView1.CameraFocalPoint = [0.0, -0.037722447887063026, 0.02939213067293167]
renderView1.CameraViewUp = [0.0, 0.0, 1.0]
renderView1.CameraParallelScale = 0.09895573753246074
# save screenshot
SaveScreenshot('/usr2/tmp/Krishnamoorthi/case0383/New/Test/4.png', magnification=1, quality=100, view=renderView1)
# save screenshot
SaveScreenshot('/usr2/tmp/Krishnamoorthi/case0383/New/Test/4,1.png', magnification=1, quality=100, view=renderView1)
#### saving camera placements for all active views
#### uncomment the following to render all views
# RenderAllViews()
# alternatively, if you want to write images, you can use SaveScreenshot(...).
Is it possible to generate pictures at certain time steps?
If yes can someone tell me where to insert the option in the code
Aravind_Krish is offline   Reply With Quote
paraview 4.4.0, screenshot
[General] Paraview Picuter generation Aravind_Krish ParaView 0 September 5, 2016 07:54
[OpenFOAM] Picture generation in Paraview Aravind_Krish ParaView 1 August 20, 2016 14:27
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
Latest News in Mesh Generation Robert Schneiders Main CFD Forum 1 February 18, 2000 00:48
Latest news in mesh generation Robert Schneiders Main CFD Forum 0 March 2, 1999 04:07
