Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
yPlus Calculation for Spalart Allmaras RANS Simulation
Like Tree2Likes
  • 2 Post By cnsidero
Old   October 3, 2017, 04:01
Default yPlus Calculation for Spalart Allmaras RANS Simulation
JD
dickcruz is on a distinguished road
Hello All,
I've been trying to use the y+ calculation option on a transient external flow case using pimpleFoam -postProcess to make sure that my mesh resolution is sufficient closer to the flow surfaces.
Unfortunately, I get zeros for all my surfaces as my min, max and average. I've found that if I run an LES on the same case, I'm able to get some numbers. Similarly, if after I run the RAS simulation, I change up my turbulence model to LES before I run the yPlus utility, I'm able to get non-zero numbers for the RAS. I'm uncertain how trustworthy this number is. But, more fundamentally, I don't understand what I'm doing wrong with the model.
Please let me know what data needs to be analyzed to figure this out.
dickcruz is offline   Reply With Quote
Old   November 19, 2017, 15:28
Default Having a similar issue!
vdeschuy is on a distinguished road
Hey,
I think I'm dealing with a similar issue!
Are you also using OF version 5?
Do you mean with 'zeros' a very low number or actually zero?
I'm having the problem where even for very coarse meshes my y+ is always smaller than 1. As in your case, when I change to LES before I postprocess yPlus, I get numbers above 1, but I'm also not sure these are trustworthy.
Maybe you or someone else has found a solution already?
vdeschuy is offline   Reply With Quote
Old   November 19, 2017, 21:40
JD
Originally Posted by vdeschuy View Post
Hey,
Hello, could you paste the contents of your nut file here, please?
Old   November 20, 2017, 04:43
Default nut file
Here you go!
This is for a case were I used a very coarse mesh, wall functions, and here I expected to see a high y+ value.
|  \\    /   O peration     | Version:  5.0                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            calculated;
        value           uniform 0;
    outlet
        type            calculated;
        value           uniform 0;
    top
        type            slip;
    bottom
        type            slip;
    cylinder
        type            nutkWallFunction;
        value           uniform 0;
    side1
        type            empty;
    side2
        type            empty;
Old   November 20, 2017, 09:41
Chris Sideroff
cnsidero is on a distinguished road
The nutkWallFunction requires k to compute y+. Checkout out the source code for that BC:
https://github.com/OpenFOAM/OpenFOAM...arField.C#L157
The SA turbulence model has no ability to compute k so it returns a value of zero for k. Checkout the source code:
https://github.com/OpenFOAM/OpenFOAM...llmaras.C#L302
Instead use the nutUWallFunction which uses a velocity instead of k to compute y+.
-Chris
hellodd and hulli like this.
cnsidero is offline   Reply With Quote
post procesing, spalart allamaras, yplusras
Simulation RANS Explode fredicenci OpenFOAM Running, Solving & CFD 4 May 23, 2017 13:29
Wrong yPlus calculation in OF 3.0.1? Kina OpenFOAM Post-Processing 9 April 30, 2017 12:00
Yplus for Multiphase Simulation Mitch CFX 0 October 31, 2007 04:10
Do RANS simulation overpredict maximum Cp? Sergio Rossi Main CFD Forum 0 May 15, 2007 09:23
Warning 097- AB Siemens 6 November 15, 2004 04:41
