Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
pressure drop using chtMultiRegionFoam
Like Tree3Likes
  • 1 Post By simrego
  • 2 Post By amdk136
Old   November 30, 2018, 05:12
Default pressure drop using chtMultiRegionFoam
Arthur
amdk136 is on a distinguished road
I am trying to get the pressure drop between 2 different patches (inlet and outlet). In my controlDict I have included "#includeFunc patchAverage", and I have tried to use the postProcess -func patchAverage tool, however it tells me that I don't have a pressure field.
Reading fields:
Executing functionObjects
surfaceFieldValue patchAverage write:
--> FOAM Warning :
    From function virtual bool Foam::functionObjects::fieldValues::surfaceFieldValue::write()
    in file fieldValues/surfaceFieldValue/surfaceFieldValue.C at line 807
    Requested field p not found in database and not processed
Time = 39.75
Within my simulations, I have a pressure difference as I have a pressure gradient (around 5 or 6). When I run the patchAverage on the outlet, I get the attached result (surfaceFieldData attached below).
I am using OpenFOAM 6, and I am unsure why it is not working. Is there a way to do this for specific patches within paraView instead of just OF? Can anyone help? Any help is appreciated!
Thank you,
Arthur
File Type: zip surfaceFieldValue.dat.zip (576 Bytes, 7 views)
amdk136 is offline   Reply With Quote
Old   December 2, 2018, 13:29
anonymous
simrego is on a distinguished road
Hi!
In chtMultiRegionFoam you have regions. So you have to add the "-region regionName" switch to your command, where regionName is the name of the region where you have that patch.
simrego is offline   Reply With Quote
Old   December 3, 2018, 09:22
Arthur
Originally Posted by simrego View Post
Hi!
Hi Simrego,
thank you for your reply! I have also tried with the "-region <region>", but when i do that I don't get a data file generated. After I posted this I tried just about every possible combination I could to no avail haha.
I'll assume it's a deeper rooted problem. Thanks for the help though!
Arthur
Old   December 3, 2018, 09:38
anonymous
Ooo sorry. Maybe I know your problem.
You just ran "postProcess -func patchAverage", right?
Try with "chtMultiRegionSimpleFoam -postProcess -func patchAverage -region <regionName>",
or you can use directly like:
chtMultiRegionSimpleFoam -postProcess -func "patchAverage(name=<patchName>, p)" -region <regionName>
I've just tried. This is working perfectly for me:
chtMultiRegionSimpleFoam -postProcess -func "patchAverage(name=inlet, p)" -region fluid -latestTime
amdk136 likes this.
Old   December 4, 2018, 07:01
Arthur
Simrego,
Thank you again for your reply! I have tried that exactly how you have stated it, including the 'chtMultiRegionFoam' & also the 'region <region>' [as well as both with the "(name=patchName, field)" and without too], however no field data file is being created still.
Seems to be a very odd situation. I don't even get a post processing folder when I include the 'chtMultiRegionFoam' part.
Would it be possible for you to upload your case directory, please? So that I can see how you have it organised etc. And to see what I'm missing! (I understand if you'd rather not as well)
Thank you again,
Arthur
Old   December 4, 2018, 14:41
anonymous
Sorry, I can't share that case with you, but you can try it on any tutorial case. If it's not working I think the problem will be in your OF.
Maybe you are using an old version with a bug? Or had you any problems during the compilation? Or just a typo in the command? Or try with a different function, ie. patchIntegrate (just for a try).
Old   December 5, 2018, 06:09
Arthur
Simrego,
I have just run my case again and used the command you gave above (adapted for my case):
chtMultiRegionFoam -postProcess -func "patchAverage(name=cyclicFluidInlet, p_rgh)" -region water -latestTime
I was running the postProcess tool without "-latestTime" which was my problem as I didn't notice it on my phone. Posting again incase anyone else has the same problem as me
Thank you very much for your help again,
Arthur
wyldckat and hdotyao like this.
Fluent cyclone pressure drop mkal FLUENT 1 February 20, 2020 00:55
How to plot pressure drop with Periodic BC? bigfans FLUENT 7 November 8, 2016 11:28
Pressure drop using Fan type BC Alexis Sack OpenFOAM Running, Solving & CFD 2 September 22, 2014 09:18
How to study pressure drop of continous phase in VOF model sajeesh FLUENT 4 February 5, 2014 22:01
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 04:23
