Write cloudFunction fields as VTK during the runtime |
January 2, 2024, 09:55 |
Ege Batmaz
Rep Power: 7 |
Dear Foamers,
I am using vtkCloud function to write lagrangian cloud field data into the postProcessing/ folder during the runtime. I am additionally calculating few more fields using the CloudFunctions class in my cloud properties file: Nusselt Number, Particle Reynolds Number and Heat Transfer Coefficient. However, vtkCloud doesn't write those additionally calculated fields (Nu, Re_p, ...) to the postProcessing/ folder even I am selecting to write all fields. Is there a way to write those additionally calculated fields as a postProcessing/VTK format during the runtime? controlDict: Code:
cloudWrite1 { type vtkCloud; libs (lagrangianFunctionObjects); writeControl runTime; writeInterval 0.01; format binary; cloud reactingCloud1; fields (".*"); } Code:
cloudFunctions { NusseltNumber1 { type NusseltNumber; } ReynoldsNumber1 { type ReynoldsNumber; } HeatTransferCoeff1 { type HeatTransferCoeff; } } Ege |
January 3, 2024, 12:26 |
Mark Olesen
Rep Power: 40 |
I took a look and I think you could have a try at just copying in data from the cloud itself.
Take a look at the writeCloud() in the vtkCloud.C code and you'll see that it uses a local temporary registry (obrTmp) where all of the normal particle output is written. Next if you examine (for example) the KinematicReynoldsNumber.C code, you'll see that the postEvolve method calculates the Reynolds number and dumps it onto the cloud itself. So based on this knowledge, it should be possible to just add in a sub-selection back into the obrTmp or even just write the additional registry for label/scalar/vector types (similar to around Line 290 of the vtkCloud.C file). Although still some snags to be expected with the filtering mechanism, it is probably a good place for you to start. EDIT: added as https://develop.openfoam.com/Develop.../-/issues/3094 Last edited by olesen; February 1, 2024 at 08:54. |
cloudfunctions, vtkcloud |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
Where to define which fields to write? | bgoeppner | OpenFOAM | 8 | July 15, 2011 11:00 |
Write PDF from probes sampling and runtime plotting | jose_rodrig | OpenFOAM | 4 | June 5, 2011 06:30 |
no write option for ddt0 fields | nikos_fb16 | OpenFOAM Programming & Development | 0 | December 1, 2009 09:29 |
write nut fields in simpleFoam | maurice | OpenFOAM Running, Solving & CFD | 5 | March 23, 2009 01:57 |
