How to compute liquid volume of the NOT whole domain
Like Tree1Likes
  • 1 Post By gschaider
Old   March 24, 2008, 22:17
Default Hi, I'd like to compute
shinji nakagawa
snak is on a distinguished road
I'd like to compute the liquid volume left in a restricted domain after an interFoam simulation. I'd like to know the liquid volume in the region of z < 1, for instance.
I have found the thread "How to compute total liquid volume of the whole domain?" related to my question.
http://www.cfd-online.com/OpenFOAM_D...tml?1184365098
The source code in the thread is quite impressive. However, I don't know how to limit the region with sum() function.
Would you please give some advice or drop a hint to me?
snak is offline   Reply With Quote
Old   March 25, 2008, 14:05
Default Hi You can iterate over the
jaswi is on a distinguished road
Hi
You can iterate over the cells in the domain while checking if cellcentre.z() < 1.0 and if the condition satisfies then add the liquid in that cell to your running sum.
hope that helps
Regards
Jaswi
jaswi is offline   Reply With Quote
Old   March 27, 2008, 22:53
Default Hi Jaswi Thank you very muc
shinji nakagawa
Hi Jaswi
Thank you very much for your advice.
I'm gonna try to write short code, though I have to learn a bit more about OpenFOAM source code.
Thanks,
snakagawa
Old   June 24, 2008, 23:19
Default Hi, I added the following s
shinji nakagawa
I added the following short code to calculate liquid volume in the specified region.
Info << " Liquid (whole domain): " << sum(mesh.V()*gamma) << endl;
sumVol = 0;
forAll(mesh.cells(),cellI)
if( mesh.C()[cellI].component(0) >= validXmin
& mesh.C()[cellI].component(0) <= validXmax
& mesh.C()[cellI].component(1) >= validYmin
& mesh.C()[cellI].component(1) <= validYmax
& mesh.C()[cellI].component(2) >= validZmin
& mesh.C()[cellI].component(2) <= validZmax )
{sumVol = sumVol + mesh.V()[cellI]*gamma[cellI]; }
Info << " Liquid in specified region: " << sumVol << endl;
Info << endl;
It works fine for a single processor calculation.
With multi-processors, however, the calculated liquid volume in the specified region is not correct. Liquid volume in whole domain is correct. I think that my code have some problem in handling the coordinates in decomposed field.
Would you please give some advice to modify the code?
Thank you in advance,
snakagawa
Old   June 25, 2008, 07:34
Default A reduce(sumVol,plusOp
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
A
reduce(sumVol,plusOp<scalar>());
before the Info might solve that. Have a look elsewhere what it actually does.
Bernhard
ThorgrimmCFD likes this.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
How to calculate liquid volume as the interface moves for interFoam Solver asaha OpenFOAM Running, Solving & CFD 25 October 21, 2009 04:34
surfaces inside a volume (domain) Johannes CFX 1 December 22, 2008 10:17
Liquid phase volume fraction sega OpenFOAM Running, Solving & CFD 23 August 21, 2008 05:58
How to compute total liquid volume of the whole domain hsieh OpenFOAM Post-Processing 2 July 13, 2007 18:18
Compute volume Tony Main CFD Forum 1 October 2, 2001 17:39
