Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
POD
Old   January 25, 2007, 07:51
Default Hi, I am interested in doin
Magnus Åberg
magnus is on a distinguished road
I am interested in doing POD of my snapshots from my scalar/vector field results. Did anyone here implement an algorithm for this already that you want to share?? I have one already in fortran that is not compatible with OpenFOAM format so it would take some effort to rewrite it.
I think such a tool would be valuable in the OpenFOAM postproc toolkit
thanks
/M
magnus is offline   Reply With Quote
Old   January 25, 2007, 08:13
Default Have a look at my presentation
Hrvoje Jasak
Have a look at my presentation at the US Navy Research labs:
http://www.foamcfd.org/resources/200..._13Nov2006.pdf
As you can see, the POD tools in OpenFOAM are working already: I am currently using POD-based data analysis on LES results (but there are several other things to be done with it as well). However, this is as yet unpublished work and a basis of some further developments close to my heart. My practice is not to release the code untli the poeple who did the work complete their publications and similar - this a very important part of the work.
If you have interest in a joint research project or similar please feel free to contact me.
Hrv
Hrvoje Jasak
Old   January 26, 2007, 10:26
Default Hi, Thanks for your answer!
Magnus Åberg
Thanks for your answer! I need to get the POD results as fast as I can, so I guess I will have to make an ugly solution of mapping the formats between the two codes (at least for now).
Regarding your presentation, I found your slide on aeroacoustics interesting (slide nr 9). Parts of my research is about evaluating acoustic fields, although I use an acoustic analogy (solving the wave equation). Would you care to expand on the method in your presentation a bit? I guess this tool is also not distributed right?
best regards!
/M
Old   March 13, 2008, 19:25
Default I wonder if the POD library is
Maka Mohu
maka is on a distinguished road
I wonder if the POD library is availble at the moment. Thanks.
Best regards,
Maka.
maka is offline   Reply With Quote
Old   April 18, 2008, 09:10
Default I'm thinking to use POD as a w
Maka Mohu
I'm thinking to use POD as a way to compress the transient data. Any experience of how efficient is it in doing such job for wall bounded flows with separation. Thanks.
Best regards,
Maka.
