[PyFoam] pyFoamSamplePlot not working with 1.6?
Old   March 31, 2010, 09:51
Default pyFoamSamplePlot not working with 1.6?
Christian Schaad
cschaad is on a distinguished road
I am working with OF-1.6 and really happy with pyFoam from the svn-repository.
I am not sure, if I'm doing something wrong or if pyFoamSamplePlot is not compatible with OF-1.6.
pyFoamSamplePlot is looking for a "samples" directory instead of the "sets" directory created by the sample command. Creating a soft link from sets to samples leads to the following error message:
PyFoam FATAL ERROR on line 123 of file OpenFOAM/ThirdParty-1.6/pyfoam/lib/python2.6/site-packages/PyFoam/Applications/SamplePlot.py : At least one line has to be specified. Found were ['data', 'data1', 'data2', 'data3']
My sampleDict contains:
interpolationScheme cellPoint;
setFormat raw;
sets
data3
type uniform;
axis distance;
start ( 1.3 0.028 0 );
end ( 1.3 -2 0 );
nPoints 1000;
surfaces ();
fields ( U );
Does anyone have similar problems or am I doing something wrong?
cschaad is offline   Reply With Quote
Old   March 31, 2010, 10:34
Assistant Moderator
Bernhard Gschaider
setFormat raw;
sets
data3
type uniform;
axis distance;
end ( 1.3 -2 0 );
nPoints 1000;
surfaces ();
fields ( U );
Have you had a look at the documentation the --help-option gives you? An excerpt from that is
Data
Select the data to plot
--line=LINE             Thesample line from which data is plotted (can be used
                        more than once)
--field=FIELD           The fields that are plotted (can be used more than
                        once). If none are specified all found fields are used
--directory-name=DIRNAME
                        Alternate name for the directory with the samples
                        (Default: samples)
This means
  1. That the symbolic link was not necessary (just say "--dir=sets" and you're ready to go
  2. The error message should be clear: specify at least on line (for instance "--line=data1", but you can also use several "--line=data1 --line=data2"
I hope you're aware that the utility itself doesn't plot anything. It just generates the appropriate gnuplot commands (but piping the output directly into gnuplot produces the pictures)
Bernhard
PS: Any hints how to improve the help-texts are welcome. User provided usage-examples on the Wiki are even more welcome
Old   March 31, 2010, 11:54
Christian Schaad
Hello Bernhard,
Thank You for your quick answer.
I already tried the options. So, the error message I get when I do
pyFoamSamplePlot.py --dir=sets --line=data1 --time=10000 .
is:
Traceback (most recent call last):
File "/home/chrisso/OpenFOAM/ThirdParty-1.6/pyfoam/bin/pyFoamSamplePlot.py", line 5, in <module>
SamplePlot()
File "/home/chrisso/OpenFOAM/ThirdParty-1.6/pyfoam/lib/python2.6/site-packages/PyFoam/Applications/SamplePlot.py", line 27, in __init__
interspersed=True)
File "/home/chrisso/OpenFOAM/ThirdParty-1.6/pyfoam/lib/python2.6/site-packages/PyFoam/Applications/PyFoamApplication.py", line 138, in __init__
self.run()
File "/home/chrisso/OpenFOAM/ThirdParty-1.6/pyfoam/lib/python2.6/site-packages/PyFoam/Applications/SamplePlot.py", line 247, in run
if abs(vRange[0]-vRange[1])>1e-5*max(abs(vRange[0]),abs(vRange[1])) and max(abs(vRange[0]),abs(vRange[1]))>1e-10:
TypeError: unsupported operand type(s) for -: 'tuple' and 'tuple'
Or am I still doing something wrong?
Old   March 31, 2010, 13:21
Assistant Moderator
Bernhard Gschaider
Hello Bernhard,
is:
SamplePlot()
interspersed=True)
self.run()
Try selecting with the --field-option only one field at a time (check with --info which fields are available). I'm afraid the problem is U (or some other vector-field)
Bernhard
Old   March 31, 2010, 17:27
Christian Schaad
Now I got it. It's working with scalar fields, but not with a vector field, in my case U.
Sadly, U.component(0) is not working with the sample utility, like mentioned here:
http://www.cfd-online.com/Forums/openfoam/72445-sample-utility-not-working-openfoam-1-6-a.html
Thank You anyway for your really powerful pyFoam,
Christian
Old   March 31, 2010, 18:30
Assistant Moderator
Bernhard Gschaider
Christian
But it should (work with vector fields). If a bug report appears at
http://sourceforge.net/apps/mantisbt...e_status_id=90
I will see what I can do for the next release (can't promise anything though)
Bernhard
solver is working in windows but not in linux jbseo CFX 0 August 30, 2016 00:20
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
[OpenFOAM.com] [v3.0+] not working anymore (note: was missing entry in .bashrc) Jambne OpenFOAM Installation 1 May 29, 2016 14:37
Is there any institutions still working on solving N-S equations? sharonyue Main CFD Forum 2 November 11, 2015 08:23
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 02:01
