Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
foamToVTK
Like Tree2Likes
  • 2 Post By wyldckat
Old   May 5, 2010, 06:29
Default foamToVTK
sam
sameer_kumar is on a distinguished road
Dear foamers,
I am getting following error at the time of converting from foamToVTK at the time of writing 40th iteration.
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 1.6-53b7f692aa41
Exec : foamToVTK
Date : May 05 2010
Time : 23:37:32
Host : localhost.localdomain
PID : 9524
Case : /home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Time: 0
volScalarFields : p nut k epsilon nuTilda
volVectorFields : U
volSymmTensorFields : R
Internal : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/couplermodified_0.vtk"
Original cells:1039528 points:222710 Additional cells:8 additional points:4
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/FEMALE_DESIGN/FEMALE_DESIGN_0.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/COUPLER/COUPLER_0.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/INLET/INLET_0.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/OUTLET/OUTLET_0.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/FM_PIN/FM_PIN_0.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/M_PIN/M_PIN_0.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/MALE_DESIGN/MALE_DESIGN_0.vtk"
FaceZone : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/int_FLUID/int_FLUID_0.vtk"
Time: 20
volVectorFields : U
Internal : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/couplermodified_20.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/FEMALE_DESIGN/FEMALE_DESIGN_20.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/COUPLER/COUPLER_20.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/INLET/INLET_20.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/OUTLET/OUTLET_20.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/FM_PIN/FM_PIN_20.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/M_PIN/M_PIN_20.vtk"
Patch : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/MALE_DESIGN/MALE_DESIGN_20.vtk"
FaceZone : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/int_FLUID/int_FLUID_20.vtk"
Time: 40
volVectorFields : U
Internal : "/home/user/OpenFOAM/OpenFOAM-1.6/run/tutorials/incompressible/simpleFoam/couplervtkfiles/couplermodified/VTK/couplermodified_40.vtk"
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/user/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/user/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::writeFuns::insert(double const&, Foam:ynamicList<float, 0u, 2u, 1u>&) in "/home/user/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/foamToVTK"
#4 void Foam::writeFuns::write<double>(std:stream&, bool, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::vtkMesh const&) in "/home/user/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/foamToVTK"
#5 main in "/home/user/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/foamToVTK"
#6 __libc_start_main in "/lib/libc.so.6"
#7 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
Please give suggestions to overcome this problem.
Regards,
Sam
sameer_kumar is offline   Reply With Quote
Old   May 6, 2010, 21:17
Retired Super Moderator
Bruno Santos
Greetings Sam and welcome to the forum!
Probably at that iteration, infinite or undefined values or even NaN (Not-A-Number) values where found on the results, but it was unable to write those out-of-bound values. You could try using:
foamToVTK -ascii
but while it might not crash with foamToVTK, Paraview on the other hand might not like seeing something like "-1#INF" in the file "40.vtk".
Check the residues of your run to see if there are any alarming values, like residues in the order of 1e+300, for that same iteration.
If you are basing yourself on an existing tutorial case from OpenFOAM 1.6, I suggest that you get the 1.6.x version; no need to build it, just get it to check the same tutorial you've based on. I say this, because the motorBike case in OpenFOAM 1.6 diverges around iteration 300, while the 1.6.x motorBike version doesn't diverge, using the same simpleFoam solver from 1.6!
Best regards,
Bruno
samiam1000 and saidc. like this.
Visualize Mesh with foamToVTK andrewryan OpenFOAM 3 October 5, 2009 09:42
FoamTOVTK yapalparvi OpenFOAM Post-Processing 3 August 12, 2009 08:19
[OpenFOAM] Too many time folders crash foamToVTK johndeas ParaView 4 September 25, 2008 15:07
[Technical] How to get polyhedral mesh without additional cells when using foamToVTK chnrdu OpenFOAM Meshing & Mesh Conversion 4 June 10, 2008 13:08
[OpenFOAM] FoamToVTK error with OF 13 melanie ParaView 1 May 22, 2006 04:40
