May 15, 2010, 12:03 |
Velocity at each Gridpoint
Rafael
Hi all!
I am post-processing OpenFoam output data with Matlab. What I need are the gridpoints and at each gridpoint the velocity. However, the output files that I get from the person who is doing the OpenFoam simulation are not easy to process. The gridpoints are listed well, no problems there. But the velocity field is splitted into so many different subsets (internalField, Inlet, Oulet,...) that it is an almost impossible task to assign one velocity to one gridpoint. Is there a way (in OpenFoam) to output velocities for each gridpoint? Some check box or some command, I don't know... Just so I get the gridpoints in an "nx3" array (n: number of gridpoints, 3: each direction) and the velocity exactly in the same format? Thank you very much for your help! Best regards |
May 16, 2010, 05:42 |
#2 | ||
Mark Olesen
Rep Power: 40 |
May 16, 2010, 08:20 |
Rafael
Thank you very much, I'll have a look at it!
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Velocity Under-relaxation in SIMPLE type methods | Matt U. | Main CFD Forum | 6 | July 4, 2005 05:29 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
