Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Calculating heat flux
Like Tree6Likes
  • 1 Post By hugo17
  • 3 Post By hugo17
  • 2 Post By Nicole
Old   August 22, 2011, 04:17
Default Calculating heat flux
hugo17 is on a distinguished road
I'm dealing with heat conduction in solids using laplacianFoam and want to calculate the heat flux through walls from Openfoam results. However, unexpected difficulties are arising which I want to explain with the following example:
The analytical result for the heat flux through the walls of the annulus shown in the figure is q"=2460.01 W/m (related to length in z direction).
1. Using wallHeatFluxLaminar (from this thread: http://www.cfd-online.com/Forums/ope...foam1-6-a.html), the following values are calculated:
Outside: q"_a=780.284 W/m^2 --> multiplication by inner circumference gives q"=2451.3 W/m
Inside: q"_i=-1299.32 W/m^2 --> q"=-2449.2 W/m
Compared to the analytical solution, these values are too small.
2. Using foamCalc magGrad T, the following values are calculated:
Outside: magGrad T=78.0284 K/m --> multiplication by k and the inner circumference gives q"=2451.3 W/m (same value as given by wallHeatFluxLaminar)
Inside: magGrad T=129.932 K/m --> q"=-2449.2 W/m
Thus, using magGrad T leads to the same heat flux as wallHeatFluxLaminar for the present example. However, this is not the case for all geometries I dealt with.
3. Calculating the gradient magnitude for myself from mag(grad T) = sqrt(gradTx^2 + gradTy^2), I obtain different heat fluxes:
Outside: sqrt(gradTx^2 + gradTy^2)=78.307 K/m --> q"=2460.09 W/m
Inside: sqrt(gradTx^2 + gradTy^2) --> q"=2460.07 W/m
These heat fluxes are very close to the analytical value.
Now, my questions are:
- Why does the gradient magnitude calculated as sqrt(gradTx^2 + gradTy^2) differ from magGrad T calculated by foamCalc?
- Why is the heat flux value calculated from sqrt(gradTx^2 + gradTy^2) apparantly "better" than this one calculated from WallHeatFluxLaminar or magGrad T?
I really appreciate any comment on this problem.
Regards
Hugo
JuanRodriguez likes this.
hugo17 is offline   Reply With Quote
Old   August 22, 2011, 05:18
I found the reason for the different results: I had writePrecision set to 6. When I increase it to 8, also wallHeatFluxLaminar and magGrad T give the correct values.
Regards
Hugo
Mojtaba.a, ancipdp and Saleh Mey like this.
Old   May 7, 2015, 18:51
Juan David Rodriguez P
JuanRodriguez is on a distinguished road
Hugo, thanks for your contribution.
I want to visualize heat flux lines (orthogonal to isotherms) in paraview. My case is a similar one to yours (heat conduction in 2D from a buried pipe to soil). Do know how to proceed?
Best,
Juan.
JuanRodriguez is offline   Reply With Quote
Old   May 27, 2015, 06:09
Nicole Andrew
Nicole is on a distinguished road
Hi Juan,
Have you had any success yet?
If you are used to modifying the solver, I would recommend just adding a new volScalarField, qFlux or something, calculated from fvc::grad(T) in the solver. I am not sure if this would be the best way.
Apparently there are also calculators in paraview, perhaps one of these would be useful?
Let me know if you want me to elaborate
prandtl Gao and gbope7 like this.
Nicole is offline   Reply With Quote
Old   May 27, 2015, 12:47
Hi Nicole,
I finally used funkySetFields to calculate grad(T). I think it is ok and am still learning to modify code in OF, but I will try what you suggest.
Thanks.
Best,
Juan.
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
Heat flux in ansys cfx juliom OpenFOAM Running, Solving & CFD 2 April 14, 2009 14:30
Calculating Heat flux Andrew Garrard FLUENT 0 July 6, 2004 05:47
