[swak4Foam] evaporation / vapor flux / groovyBC
Old   December 4, 2011, 22:17
Smile evaporation / vapor flux / groovyBC
shinya ogata
oga_shin is on a distinguished road
Hi!
I want to calculate water evaporation with simpleFoam.
I have already added moisture field as X in simpleFoam solver.
And then, I am trying to make evaporation boundary using groovyBC.
I wrote a boundary condition of vapor flux referring to heat flux.
z_
type groovyBC;
value uniform 0;
gradientExpression "gradX";
fractionExpression "0";
variables
"alphac=5.8+3.9*mag(internalField(U));Xs=0.0167;al fadash=3.6*alphac/3600;capadash=1;rhodash=1.2;gradX=alfadash*(Xs-internalField(X))/(kappaEffX*capadash*rhodash);";
SimpleFoam has done without any error.
But amount of water evaporation is too little comparing to a experiment data.
Is the boundary condition which I wrote right ?
Shinya
oga_shin is offline   Reply With Quote
Old   December 5, 2011, 04:57
Assistant Moderator
Bernhard Gschaider
Originally Posted by oga_shin View Post
Hi!
z_
type groovyBC;
value uniform 0;
variables
Shinya
Don't know. Just two remarks:
a) never trust experimental data
b) if you use internalField like that I'd expect some kind of grid dependence. Try changing the resolution and see if that makes a difference
Old   December 11, 2011, 00:53
shinya ogata
Hi gschaider !
Thank you for your advise!
I subdivided mesh and the amount of evaporation changed.
As you pointed, it could be mesh dependence.
I will try to find appropriate mesh.
Thank you again.
Shinya
Old   December 11, 2011, 06:14
Assistant Moderator
Bernhard Gschaider
Hi gschaider !
Thank you again.
Shinya
Don't adapt the mesh to fit your results. Try to find a mesh-independent formulation. Something that might help you are these functions:
http://openfoamwiki.net/index.php/Co...g_to_need_are:
Good luck
Old   December 13, 2011, 03:43
shinya ogata
Hi gschaider !
Your advise is right.
Even if I found appropriate mesh comparing with experiment,
I cannot use it with another model.
I will try to make mesh-independent formulation.
Thank you again.
Shinya
evaporation groovybc
Water Surface Evaporation sunggun1212 FLUENT 3 January 11, 2020 04:12
[swak4Foam] groovyBC for oscillatory flow liybzd OpenFOAM Community Contributions 5 November 12, 2018 07:53
[swak4Foam] reactingMultiPhaseEulerFoam problems with groovyBC zanilu70 OpenFOAM Community Contributions 4 December 13, 2016 06:46
[swak4Foam] Change in alpha and U with groovyBC in twoPhaseEulerFoam dani2702 OpenFOAM Community Contributions 0 November 17, 2016 03:30
Liquid Evaporation Model Error in OF 2.3.0 brbbhatti OpenFOAM 11 June 16, 2014 09:40
