[PyFoam] How to return initial scale in gnuplot whire running pyFoamPlotRunner..
Old   December 27, 2011, 05:18
Question How to return initial scale in gnuplot whire running pyFoamPlotRunner..
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
Hello.
I have a problem -
when I run any OF case threw pyFoam plot utility as
pyFoamPlotRunner.py <OFsolverName>
..appear gnuplot window and I can select by mouse click any area on it for increasing scale..
So how I can return to default scale? Is it possible at all?
Thank for some advice.
j-avdeev is offline   Reply With Quote
Old   December 27, 2011, 07:45
Assistant Moderator
Bernhard Gschaider
Originally Posted by j-avdeev View Post
Hello.
I have a problem -
I think 'h' should give you a list of the keystrokes that the X11-gnuplot-window accepts. It should be something like the list here http://www.cs.unc.edu/~jeffay/dirt/FAQ/gnuplot.html (so the key 'u' should do what you want to)
chtMultiRegionSimpleFoam turbulent case Aditya Patil OpenFOAM Running, Solving & CFD 6 April 24, 2017 22:13
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 05:07
settlingFoam unstable? bendel_boy OpenFOAM Running, Solving & CFD 38 July 8, 2016 05:07
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 21:33
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
