Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Post-Processing
Version sniffing in sampleDict
Old   April 13, 2012, 05:03
Default Version sniffing in sampleDict
hugo17 is on a distinguished road
I'm working with OF 1.7.1 and 2.0 on different machines and having the problem that the old version demands "patchName mypatch" in the definition for the sample surface while the code is "patches (mypatch)" in OF 2.0. Is there any possibility to include a switch into sampleDict which makes each version reading the appropriate definition?
Best regards
Hugo
hugo17 is offline   Reply With Quote
Old   April 13, 2012, 16:52
Retired Super Moderator
Bruno Santos
Hi Hugo,
You'll have to think the other way around, namely having two separate sampleDict files and then call depending on the version of OpenFOAM:
case $WM_PROJECT_VERSION in
 1.7.*)
   sampleDict -dict sampleDict.17
  2.*)
   sampleDict -dict sampleDict.2
esac
In case you can re-use most of the file, then you can try the "#include" capability that OpenFOAM has, but I can't remember if 1.7.* had it already
Best regards,
Bruno
Old   April 16, 2012, 07:05
Thank you very much, Bruno - this way is a good idea.
Best regards
Hugo
wmake error zxj160 OpenFOAM 0 March 26, 2012 10:52
paraview installation woes vex OpenFOAM Installation 15 January 30, 2011 07:11
bubbleFoam validation case balkrishna OpenFOAM Running, Solving & CFD 24 August 30, 2010 04:37
[OpenFOAM] Problem with paraFoam on a linux-64 bit bunni ParaView 4 April 14, 2010 20:55
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
