May 15, 2012, 12:56 |
gmsh + orientation?
Rep Power: 14 |
I am using CentFoam at my CentOS machine.
The current project is to test the cavity tutorial with a different geometry, ie the front and back walls are half circles instead of the original rectangles. gmsh creates the 3D mesh, ie the msh file. Tested it with checkMesh and the error message is: Code:
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 2038 faces: 18720 internal faces: 17740 cells: 9115 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 9115 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface topology top 76 78 ok (non-closed singly connected) bottom 124 126 ok (non-closed singly connected) back 390 246 ok (non-closed singly connected) front 390 246 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (0 -4.99358 0) (10 0 0.1) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (1.17825e-19 1.39248e-18 1.56129e-16) OK. ***High aspect ratio cells found, Max aspect ratio: 8.98903e+197, number of cells 3 <<Writing 3 cells with high aspect ratio to set highAspectRatioCells Minumum face area = 0.000117197. Maximum face area = 0.195124. Face area magnitudes OK. Min volume = 1.33333e-300. Max volume = 0.00325207. Total volume = 3.92027. Cell volumes OK. Mesh non-orthogonality Max: 85.6854 average: 54.7686 *Number of severely non-orthogonal faces: 4053. Non-orthogonality check OK. <<Writing 4053 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 12 faces are incorrectly oriented. <<Writing 12 faces with incorrect orientation to set wrongOrientedFaces Max skewness = 1.32807 OK. Coupled point location match (average 0) OK. Failed 2 mesh checks. End Code:
cl1 = 0.5; Point(1) = {0, 0, 0, cl1}; Point(2) = {10, 0, 0, cl1}; Point(3) = {5, 0, 0, cl1}; Point(4) = {0, 0, 0.1, cl1}; Point(5) = {10, 0, 0.1, cl1}; Point(6) = {5, 0, 0.1, cl1}; Line(1) = {1, 2}; Line(2) = {4, 5}; Circle(3) = {1, 3, 2}; Circle(4) = {4, 6, 5}; Line(5) = {1, 4}; Line(6) = {2, 5}; Line Loop(10) = {-2, -5, 1, 6}; Plane Surface(10) = {10}; Line Loop(12) = {-6, -3, 5, 4}; Plane Surface(12) = {12}; Line Loop(14) = {2, -4}; Plane Surface(14) = {14}; Line Loop(16) = {3, -1}; Plane Surface(16) = {16}; Surface Loop(68) = {10, 12, 14, 16}; Volume(68) = {68}; Physical Surface("front") = {16}; Physical Surface("back") = {14}; Physical Surface("bottom") = {12}; Physical Surface("top") = {10}; Physical Volume("internal") = {68}; |
May 15, 2012, 13:08 |
Floating point exception
Rep Power: 14 |
It is possible OpenFOAM still works when checkMesh finds errors. Right?
So I continue to gmshToFoam the msh file, modify the initial p, U, and boundary accordingly. Then run icoFoam, Code:
Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.005 Courant Number mean: 0 max: 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.36138e-06, No Iterations 3 DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 DICPCG: Solving for p, Initial residual = 1, Final residual = 9.74703e-07, No Iterations 227 time step continuity errors : sum local = 2.9243e-11, global = -9.77389e-23, cumulative = -9.77389e-23 #0 Foam::error::printStack(Foam::Ostream&) in "$RUN/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "$RUN/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 void Foam::fvc::surfaceIntegrate<double>(Foam::Field<double>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "$RUN/platforms/linux64GccDPOpt/bin/icoFoam" #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::surfaceIntegrate<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "$RUN/platforms/linux64GccDPOpt/bin/icoFoam" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::div<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "$RUN/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #6 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "$RUN/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #7 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "$RUN/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #8 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "$RUN/platforms/linux64GccDPOpt/bin/icoFoam" #9 _ZN4Foam3fvm9laplacianIddEENS_3tmpINS_8fvMatrixIT_EEEERKNS_14GeometricFieldIT0_NS_12fvPatchFieldENS_7volMeshEEERKNS7_IS4_S9_SA_EE.constprop.416 at icoFoam.C:0 #10 main in "$RUN/platforms/linux64GccDPOpt/bin/icoFoam" #11 __libc_start_main in "/lib64/libc.so.6" #12 Foam::regIOobject::writeObject(Foam::IOstream::streamFormat, Foam::IOstream::versionNumber, Foam::IOstream::compressionType) const in "$RUN/platforms/linux64GccDPOpt/bin/icoFoam" Floating point exception highAspectRatioCells nonAlignedEdges nonOrthoFaces wrongOrientedFaces |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview | zhernadi | OpenFOAM Meshing & Mesh Conversion | 8 | July 7, 2011 02:28 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
[Gmsh] Error converting Gmsh mesh to OpenFOAM format | Martin_ | OpenFOAM Meshing & Mesh Conversion | 3 | December 9, 2009 09:35 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
