July 16, 2012, 17:02 |
turbulentHeatFluxTemperature
Nikunj Raithatha
Rep Power: 13 |
Hello All!
I am trying to implement the trubulent heat flux temperature BC in my model. I think, I have successfully recompiled the BuoyanBoussinesqPimpleFoam solver to be able to use the above BC (as described in this discussion: http://www.cfd-online.com/Forums/ope...oussinesq.html). When running a test case with the recompiled solver, I am getting following error. FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 36 the word 'Cp0' file: /home/eri/OpenFOAM/eri-2.1.1/run/tutorials/heatTransfer/buoyantBoussinesqPimpleFoam/FullCylinderWater/constant/transportProperties::Cp0 at line 36. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 91. FOAM exiting Attached below are the files i used. Any help will be greatly appreciated. Thanks, Nikunj. |
