August 10, 2012, 08:08 |
Minimum value BC?
Adam
Rep Power: 14 |
Is it possible to set a Neumann type boundary conditions (zeroGradient), but constrain it to a minimum or maximum value? For example, I have a T-junction with one inlet and two outlets. I know the velocity of one outlet (10 ft/s), so I know that the inlet must be at least 10 ft/s, but could be greater if there is any flow out of the second outlet. How can I set the inlet velocity to have a minimum value of 10 ft/s?
Thanks. |
Minimum PDF Table Temperature | jamesmaca | FLUENT | 15 | April 8, 2022 13:30 |
how to calculate minimum force needed to start a motion | doctsh | FLUENT | 1 | December 27, 2011 21:02 |
How to calculate minimum force required to start motion? | doctsh | FLOW-3D | 0 | December 27, 2011 07:20 |
Setting a minimum temperature value | WillemvdM | OpenFOAM Running, Solving & CFD | 0 | February 3, 2010 02:37 |
UDF to monitor minimum pressure on the wall | Arvind Jayaprakash | FLUENT | 0 | September 20, 2007 11:53 |
