October 27, 2012, 17:49 |
can not complie fluentDataToFoam in OF2.1.1
Rep Power: 16 |
hi
Now I followed the instruction http://openfoam-extend.git.sourcefor...ToFoam;hb=HEAD to compile fluentDataToFoam ultily in OF2.1.1 for 64bit, but it didn't work and gave me such information. ~/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/preProcessing/fluentDataToFoam $ wmake g++ -c -o fluentDataConverter.o fluentDataConverter.C In file included from fluentDataConverter.C:27:0: fluentDataConverter.H:42:19: fatal error: fvCFD.H: No such file or directory compilation terminated. make: *** [fluentDataConverter.o] Error 1 can somebody tell me what should I do? thank you very much in advance! |
October 28, 2012, 12:48 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings hewei,
Something is not right in the output you've given. After you run wmake, it should output something like this: Code:
user@machine:~/OpenFOAM/user-2.1.x/foamDataToFluent21x$ wmake Making dependency list for source file writeFluentScalarField.C Making dependency list for source file writeFluentVectorField.C Making dependency list for source file foamDataToFluent.C SOURCE=writeFluentScalarField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/writeFluentScalarField.o SOURCE=writeFluentVectorField.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/writeFluentVectorField.o SOURCE=foamDataToFluent.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/foamDataToFluent.o g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude -I/home/user/OpenFOAM/OpenFOAM-2.1.x/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/writeFluentScalarField.o Make/linux64GccDPOpt/writeFluentVectorField.o Make/linux64GccDPOpt/foamDataToFluent.o -L/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lOpenFOAM -ldl -lm -o /home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/bin/foamDataToFluent Code:
ls -l $FOAM_SRC/finiteVolume/lnInclude/fvCFD.H Best regards, Bruno
November 6, 2012, 18:53 |
#3 | |
Rep Power: 16 |
Hi Bruno,thanks for your help. I followed your advice,but it still not succeed. wei@weihe ~/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/preProcessing/fluentDataToFoam $ ls -l $FOAM_SRC/finiteVolume/lnInclude/fvCFD.H lrwxrwxrwx 1 wei wei 35 May 25 06:45 /home/wei/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude/fvCFD.H -> ../cfdTools/general/include/fvCFD.H wei@weihe ~/OpenFOAM/OpenFOAM-2.1.1/applications/utilities/preProcessing/fluentDataToFoam $ wmake SOURCE=fluentDataConverter.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/home/wei/OpenFOAM/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/home/wei/OpenFOAM/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/home/wei/OpenFOAM/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/fluentDataConverter.o In file included from fluentDataConverter.C:27:0: fluentDataConverter.H:43:24: fatal error: wordIOList.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/fluentDataConverter.o] Error 1 yours, wei. |
November 7, 2012, 07:59 |
Bruno Santos
Rep Power: 128 |
Hi Wei,
I've got a feeling that something strange is happening in your machine... namely that files aren't being properly picked up by the compiler!? You can try the following pseudo-trick for forcing a folder refresh, so that the compiler can access to a fresh list of files: Code:
find $FOAM_SRC -name wordIOList.H The only reason I can remember for this issue to be occurring is if you are either sharing the OpenFOAM folder inside a virtual machine or if the folder is located at a remote file-system. Any of those cases would lead to a stale list of files, leading to the issue you're having. Best regards, Bruno
November 7, 2012, 08:17 |
Rep Power: 14 |
Hello Wei,
The link you provided, is to a utility for OpenFOAM-1.6-ext. So it is not a utility for OpenFOAM 2.1.1. The error you encountered, means, that the compiler can't find one of the files (here wordIOList.H). I looked in my OF2.1.1 and there is no such file. To use the code in OF211 you need to substitute the wordIOList class in the code with a class provided from OF211. So more or less you need to rewrite the utility for OF211, which means you need knowledge in programming. Sorry, that I can't help you any further. |
November 7, 2012, 15:24 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@blacksquirrel: Good catch! I had replied without checking with any OpenFOAM installation and assumed the error was related to the previous one . My first mistake was that I misread the application name... I thought it was "foamDataToFluent", which is already provided with the original OpenFOAM, while Wei wants "fluentDataToFoam". @Wei: the trick here is to copy the file "src/OpenFOAM/primitives/Lists/wordIOList.C" and "wordIOList.H" from 1.6-ext into your custom folder for "fluentDataToFoam", then edit the file "Make/files" and add "wordIOList.C" to the file list. Then it should work! Best regards, Bruno
November 7, 2012, 18:42 |
#7 | |
Rep Power: 16 |
yours, Wei |
February 11, 2013, 12:00 |
#8 | |
CJ
Rep Power: 16 |
Thanks for all the information shared above.
Indeed it compiled successfully, while when I converted data, it gives error: "file: /vsc-mounts/OpenFOAM/vsc30-2.1.x/run/cases/ENT/test/constant/polyMesh/zoneToPatchName at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. From "fluentDataToFoam.C", object:" zoneToPatchName" must be read, any one has this file? Or some other advice to solve the problem. Thanks a lot in advance! Quote:
March 8, 2013, 18:03 |
#9 | |
DDB
Rep Power: 13 |
I found that the link did not work :-( So I downloaded the entire iso for OF-1.6-ext and copied the openfoam folder with src code etc. Then I edited the Make/files Quote:
When I ran wmake I got Code:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/opt/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/fluentDataConverter.o Make/linux64GccDPOpt/fluentDataToFoam.o Make/linux64GccDPOpt/wordIOList.o -L/opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lOpenFOAM -ldl -lm -o /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/fluentDataToFoam /usr/bin/ld: cannot open output file /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/fluentDataToFoam: Permission denied collect2: error: ld returned 1 exit status make: *** [/opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/fluentDataToFoam] Error 1 Code:
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM-2.1.1/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude -I/opt/OpenFOAM-2.1.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64GccDPOpt/fluentDataConverter.o Make/linux64GccDPOpt/fluentDataToFoam.o Make/linux64GccDPOpt/wordIOList.o -L/opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib \ -lfiniteVolume -lOpenFOAM -ldl -lm -o /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/fluentDataToFoam /usr/bin/ld: warning: libtriSurface.so, needed by /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so, not found (try using -rpath or -rpath-link) /usr/bin/ld: warning: libmeshTools.so, needed by /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so, not found (try using -rpath or -rpath-link) /usr/bin/ld: warning: libPstream.so, needed by /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so, not found (try using -rpath or -rpath-link) /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::NamedEnum<Foam::mappedPatchBase::sampleMode, 4>::names' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::pointToPointPlanarInterpolation::findTime(Foam::List<Foam::instant> const&, int, double, int&, int&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::~coordinateSystem()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::reduce(double&, Foam::sumOp<double> const&, int)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UIPstream::read(Foam::UPstream::commsTypes, int, char*, long, int)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellSet::~cellSet()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::cellDistFuncs(Foam::polyMesh const&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::correctBoundaryFaceCells(Foam::HashSet<int, Foam::Hash<int> > const&, Foam::Field<double>&, Foam::Map<int>&) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UIPstream::UIPstream(Foam::UPstream::commsTypes, int, Foam::DynamicList<char, 0u, 2u, 1u>&, int&, int, bool, Foam::IOstream::streamFormat, Foam::IOstream::versionNumber)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `vtable for Foam::cyclicAMILduInterfaceField' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::calcMapping() const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `typeinfo for Foam::mappedPatchBase' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `typeinfo for Foam::cyclicAMILduInterfaceField' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::faceSet::~faceSet()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::calcAMI() const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::faceSet::faceSet(Foam::polyMesh const&, Foam::word const&, int, Foam::IOobject::writeOption)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cyclicAMILduInterfaceField::~cyclicAMILduInterfaceField()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UPstream::waitRequests(int)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::samplePoints() const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::abort()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::pointToPointPlanarInterpolation::timeNames(Foam::List<Foam::instant> const&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::faceSet::faceSet(Foam::polyMesh const&, Foam::word const&, Foam::HashSet<int, Foam::Hash<int> > const&, Foam::IOobject::writeOption)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellSet::cellSet(Foam::polyMesh const&, Foam::word const&, Foam::IOobject::readOption, Foam::IOobject::writeOption)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::patchWave::patchWave(Foam::polyMesh const&, Foam::HashSet<int, Foam::Hash<int> > const&, bool)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::getPointNeighbours(Foam::PrimitivePatch<Foam::face, Foam::SubList, Foam::Field<Foam::Vector<double> > const&, Foam::Vector<double> > const&, int, Foam::List<int>&) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `typeinfo for Foam::cyclicAMILduInterface' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cyclicAMIPolyPatch::AMI() const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::operator<<(Foam::Ostream&, Foam::wallPoint const&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::init(int&, char**&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::sampleMesh() const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UIPstream::UIPstream(int, Foam::PstreamBuffers&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cyclicAMIPolyPatch::typeName' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::~mappedPatchBase()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UPstream::nRequests()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::mappedPatchBase(Foam::polyPatch const&, Foam::dictionary const&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::mappedPatchBase(Foam::polyPatch const&, Foam::mappedPatchBase const&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::samplePolyPatch() const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::maxPatchSize(Foam::HashSet<int, Foam::Hash<int> > const&) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::correctBoundaryPointCells(Foam::HashSet<int, Foam::Hash<int> > const&, Foam::Field<double>&, Foam::Map<int>&) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::typeName' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `typeinfo for Foam::cyclicAMIPolyPatch' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::sumPatchSize(Foam::HashSet<int, Foam::Hash<int> > const&) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cyclicAMILduInterface::~cyclicAMILduInterface()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::addValidParOptions(Foam::HashTable<Foam::string, Foam::word, Foam::string::hash>&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so: undefined reference to `Foam::UPstream::exit(int)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::smallestDist(Foam::Vector<double> const&, Foam::polyPatch const&, int, Foam::List<int> const&, int&) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::writeDict(Foam::Ostream&, bool) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::mappedPatchBase(Foam::polyPatch const&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::patchWave::~patchWave()' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::operator>>(Foam::Istream&, Foam::wallPoint&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::mappedPatchBase::write(Foam::Ostream&) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::UOPstream::write(Foam::UPstream::commsTypes, int, char const*, long, int)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cellDistFuncs::cellDistFuncs(Foam::polyMesh const&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::coordinateSystem::coordinateSystem(Foam::dictionary const&, Foam::objectRegistry const&)' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::cyclicAMILduInterfaceField::transformCoupleField(Foam::Field<double>&, unsigned char) const' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::FaceCellWaveName::debug' /opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so: undefined reference to `Foam::pointToPointPlanarInterpolation::pointToPointPlanarInterpolation(Foam::Field<Foam::Vector<double> > const&, Foam::Field<Foam::Vector<double> > const&, double)' collect2: error: ld returned 1 exit status make: *** [/opt/OpenFOAM-2.1.1/platforms/linux64GccDPOpt/bin/fluentDataToFoam] Error 1 If anyone could help me then I would be really grateful....! Thanks in advance :-) |
March 8, 2013, 18:14 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi DDB,
Best regards, Bruno
March 9, 2013, 07:27 |
#11 |
DDB
Rep Power: 13 |
Thank you very much wyldckat, it worked a treat :-)
March 9, 2013, 07:32 |
#12 | |
DDB
Rep Power: 13 |
constant/polyMesh/zoneToPatchName at line 0 |
March 10, 2013, 10:43 |
#13 | |
Bruno Santos
Rep Power: 128 |
March 18, 2013, 16:06 |
#14 | |
Rep Power: 13 |
since the link is down, where can I get the utility fluentDataToFoam? I searched but did not found the place. Thank you so much. best H Quote:
March 18, 2013, 16:40 |
#15 | |
Bruno Santos
Rep Power: 128 |
Greetings hz283,
Did you see post #4 on the link in the quote you've given? Quote:
Best regards, Bruno
March 19, 2013, 09:04 |
#16 |
Rep Power: 13 |
Hi Bruno,
Thank you so much for your reply. Yes I found that, but I did not find the source package of FluentDataToFoam. You mentioned the folder: "applications/utilities/preProcessing/fluentDataToFoam". Is this in the OF1.6-ext ? I am using OF211, but there is no such package in the applications/utilities/preProcessing/. Thank you again. |
March 24, 2013, 12:03 |
#17 | |
Bruno Santos
Rep Power: 128 |
Hi hz283,
The application is located at: http://repo.or.cz/w/OpenFOAM-1.6-ext...uentDataToFoam You can use the links on the top of the page for getting a snapshot of the complete source code: Quote:
Best regards, Bruno
April 1, 2014, 02:24 |
#18 | |
Zhiyuan Li
Rep Power: 12 |
Hi Bruno,
Thank you for your advices about the topic. I wish to know if the method can be used in OpenFOAM-2.2.2? Quote:
Zhiyuan |
April 1, 2014, 20:51 |
#20 |
Zhiyuan Li
Rep Power: 12 |
[OpenFOAM.org] Can't find files when install OF2.1.1 on Mac | hewei | OpenFOAM Installation | 10 | June 3, 2016 06:50 |
I am beginner to complie udf. Help me , please T.T | Ukxang | Fluent UDF and Scheme Programming | 4 | July 2, 2013 01:53 |
conjugateheatfoam complie on OF1.7 | kamkari | OpenFOAM | 0 | March 10, 2011 12:11 |
about complie define_adjust() | shuqin | FLUENT | 3 | December 26, 2005 07:08 |
FluentDataToFoam utility | ali | OpenFOAM Post-Processing | 1 | November 24, 2005 13:44 |
