Why I don't get the temp gradient in a simple heat conduction case?
Old   May 1, 2013, 15:16
Default Why I don't get the temp gradient in a simple heat conduction case?
zania is on a distinguished road
Hello
I modified the flange tutorial to get the temp gradient through a simple rectangle.
I only get the temp red in the down side and the rest is all blue (Itried viewing section).
What is my mistake?
Thanks
application laplacianFoam; (I also tried leaving out the time term)
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 293;
boundaryField
frontAndBack
type zeroGradient;
up
type fixedValue;
value uniform 293;
leftLet
type zeroGradient;
rightLet
type zeroGradient;
down
type fixedValue;
value uniform 313;
zania is offline   Reply With Quote
Old   May 7, 2013, 03:17
I got it running by modifying the Allrun file
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
A simple tube FSI case can't converge stickjohnson OpenFOAM 1 June 23, 2014 21:42
estimating temp. gradient from temp. field xiyuqiu Main CFD Forum 2 April 12, 2013 17:22
Simple heat conduction through a plate vasu OpenFOAM Running, Solving & CFD 0 May 18, 2006 03:01
Need help on simple CFD case. (using CFD-ACE+) Sean Main CFD Forum 1 September 30, 2005 10:05
