Runing cavity on Discretizer
Like Tree1Likes
  • 1 Post By nimasam
Old   June 21, 2013, 13:01
Default Runing cavity on Discretizer
Tom
RTom is on a distinguished road
Hello I'm trying to run the cavity case of OpenFOAM UserGuide in Discretizer, but looks like Discretizer cannot take the moving walls conditions like OpenFOAM.
The results are different.
If check the "p.text" file on directory "0" I will see that Discretizer always needs a p fixedValue in at least 1wall and does not admit a zeroGradient on all walls; when the OpenFOAM accept a p zeroGradient on all walls.
The case I'm trying to simulate on Discretizer is "cavity", according to the UserGuide.pdf that you can find it in opt/openfoam201/doc
Can this case be run in Discretizer?
RTom is offline   Reply With Quote
Old   June 22, 2013, 08:53
Nima Samkhaniani
nimasam is on a distinguished road
solvers need to know the pressure of atleast one point ,
reference point or refrence cell for pressure, can be assigned at fvSolution in piso or pimple sub dict
RTom likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 22, 2013, 23:00
Tom
Oh thanks! it works!
I established the pRefCell and pRefValue in fvSolution directly from the .text document (in the "system" directory)
But is there a way to make this change it directly from Driscretizer GUI? I know how to set the nCorrectors and nNonOrthogonalCorrectors of fvSolution.text with the GUI, but I don't find a way to set the pRefCell and pRefValue from the GUI
Old   June 25, 2013, 01:11
immortality's Avatar
Ehsan
immortality is on a distinguished road
hi Tom
Continuing from privates so discretizer is a GUI for OF that can also used for optimization purposes.can it be combined with dakota also in your opinion.
Thats nice to be updated and support more as dear Bruno said in another thread about Discretizer.
I mistake it by digitizer thats for figures.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
discretizer
Urgent: Unsteady 3-D supersonic cavity flow Min-Sung Kang FLUENT 3 April 6, 2014 09:50
[Discretizer] Discretizer Rajshekar OpenFOAM Community Contributions 2 November 23, 2010 11:13
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 01:55
cavity in flat plate and drag prediction Far FLUENT 0 May 19, 2010 14:47
drag of flat plate with cavity Far FLUENT 0 May 18, 2010 04:57
