July 24, 2013, 23:18 |
Using setFieldDict for a wedge......
Vishal
Rep Power: 13 |
HI
I want to use setFieldDict for a wedge of a cylinder(D=0.138; H=1.38). I have 5 degree wadge. Can anyone suggest something? |
July 26, 2013, 12:38 |
Nima Samkhaniani
Rep Power: 24 |
whats the problem of using setFieldDict? could describe more precisely your problem
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
July 28, 2013, 23:57 |
Vishal
Rep Power: 13 |
Thank you for your reply Nima Sam.
I wanted to simulate 2D axisymmetric bubble column of the dimensions above mentioned. For this case I have chosen a wedge of 5 degrees. My column height is 1.38 m (as mentioned earlier) and the liquid height in the column is 0.9 m. In order to specify the liquid and gas heights separately I need to use this setFieldDict. I mention these gas and liquid heights in the column by defining phase fractions. For an example I am attaching setFieldDict file, which I have used for 3D simulations of same column. |
[blockMesh] Problems in creating a wedge type mesh | Joscha | OpenFOAM Meshing & Mesh Conversion | 28 | August 3, 2019 07:59 |
Axisymmetric Whirl BCs; Wedge or Cyclic? | c_dowd | OpenFOAM Pre-Processing | 4 | December 5, 2012 10:38 |
Wedge and morpher | Henry Arrigo | STAR-CCM+ | 5 | July 6, 2012 18:34 |
axisymmetric wedge case problem | comedy_tigers88 | OpenFOAM Running, Solving & CFD | 0 | June 16, 2012 04:45 |
Wall boundary is ignored when using wedge | Wedge | OpenFOAM | 1 | February 7, 2011 06:20 |
