topoSet
Old   October 19, 2013, 01:23
Default topoSet
mohsen kh
m5m5kh is on a distinguished road
Hi Foamers
I want to define a sphere inside a cubic block and cubic block it self as a porous media.I know I should use topoSetDict but I have no idea how to define the sphere as a porous medium.
I used celltobox for defining my domain as as a porous medium in my previous case.
what should I do?
regards
Mohsen
m5m5kh is offline   Reply With Quote
Old   October 19, 2013, 04:57
Retired Super Moderator
Bruno Santos
Hi Mohsen,
Have a look into this file: https://github.com/OpenFOAM/OpenFOAM...et/topoSetDict
You can find it on your system by running:
find $FOAM_UTILITIES  -name topoSetDict
But keep in mind that if your internal mesh isn't already cut into the shape of the sphere, then all you get is a selection of the cells that are inside the sphere selection.
Best regards,
Bruno
Old   October 19, 2013, 05:53
mohsen kh
hi bruno
I know spheretocell is good
but how should I cut the sphere out of the cubic domain?
for example I used topoSet in terminal and define the origin and radius of sphere for porosity 0.5 and I want to set the prosity for cubic domain around the sphere as for example 0.2
what should I do with that domain ?
is the zone to cell OK?
br
Mohsen
Originally Posted by wyldckat View Post
Hi Mohsen,
Best regards,
Bruno
Old   October 19, 2013, 06:24
Bruno Santos
Quick answer: read the thread http://www.cfd-online.com/Forums/ope...mesh-used.html - there you'll find how 2 meshes are created, where one is shaped like a sphere and the other is a cube that is around that sphere, then they are merged+stiched together.
Old   October 19, 2013, 06:46
mohsen kh
thanks bruno
I will follow it
br
Mohsen
topoSet simpleFoam parallelized run error HakikiCanakkaleli OpenFOAM Pre-Processing 5 October 5, 2018 10:52
Possible to create cyliner baffle (internal) using topoSet or stl Mesh? keepfit OpenFOAM 4 February 19, 2017 14:40
[mesh manipulation] Problem with topoSet and FaceZone creation ADGlassby OpenFOAM Meshing & Mesh Conversion 7 September 16, 2013 11:05
[snappyHexMesh] HOW to set a circular face by toposet Jessica OpenFOAM Meshing & Mesh Conversion 2 September 12, 2013 20:54
Can post-processing use topoSet and createPatch without screwing up the results? karkar OpenFOAM Post-Processing 0 July 24, 2012 05:41
