October 24, 2013, 12:59 |
How does porousSimpleFoam work?
Rep Power: 12 |
Hey,
I am pretty new to OpenFOAM. In my case i wanna simulate a multitubular reactor using the porousSimpleFoam solver. To get into OpenFOAM I started with a simulation of a 2 D plane with a porous zone in the middle. I reconfigured the angleDuctImplicit example to do so and it worked fine. Unfortunately I don't really get why. The walls along the porosity zone are called "porosityWalls" just like in the example. Now there's the thing I don't get. How does OpenFOAM know, where the porous media is located at? In the porosityProperties file it looks something like this: porosity1 { cellZone: porosity; Isn't it necessary to use the same names as in the blockMeshDikt file? Thank you! tehzap |
October 25, 2013, 05:06 |
Hi
Reza
Rep Power: 14 |
As I know, it should be modified when you define the geometry, so you should define the porous zone in constant/polymesh/blockmesh directory.
October 25, 2013, 14:49 |
Johannes Probst
Rep Power: 12 |
OpenFOAM will know which cells are porous medium from a so called cellSet. In the examples where the meshes are created using blockMesh, the blockMeshDict is already modified so you will get cellSets during mesh creation.
If you created the mesh without cellSets or if you don't use blockMesh you can always create a cellSet on an existing mesh using the onboard utility topoSet. In system/topoSetDict, try an entry like Code:
actions ( { name porosity; type cellSet; action new; source boxToCell; sourceInfo { box (-1 -1 -1) (1 1 1); } } ); You can have several cellSets with different names and hence use different parameters on them. And you can define other geometries than a box. OpenFOAM has cylinders, spheres and the like. Last edited by jprobst; October 26, 2013 at 04:04. Reason: formulated things a little bit clearer |
October 26, 2013, 02:52 |
mohsen kh
Rep Power: 14 |
Hi
1. you should import your file to OF for example for a fluent file you should you fluentMeshToFoam filename.msh (for 2D case) or fluent3DMeshToFoam filename.msh (for 3D case) note: there is 2 space between command and file name 2. you should modify porous zone for this step you should use topoSetdict file in your system folder in your case directory you can see this link to choose what you want.it describes all forms of defining a zone https://github.com/OpenFOAM/OpenFOAM...et/topoSetDict then use setsToZones in terminal 3. you should modify D and F which are darcy and forchheimer coefficients.I describe it in this thread http://www.cfd-online.com/Forums/ope...simplefom.html you should define them in a porosityProperties file in your constant folder in your case directory I suppose you can modify transportProperties and RASProperties. 4. finally you should use boundary condition in 0 folder and modify U and P. then just use porousSimpleFoam and analyze your result I wish you success !!! Best Regards Mohsen |
July 28, 2017, 00:50 |
Possibly useful reference
Rep Power: 15 |
Hello All,
This Tech Report may prove helpful for those having difficulty understanding Darcy-Forchheimer settings in OpenFOAM. Kind Regards, RygeltheXVI |
porousSimpleFoam | aban | OpenFOAM | 10 | July 20, 2022 03:01 |
How to work with constant pressure? | Martin | Siemens | 2 | February 25, 2009 13:23 |
Getting FoamX to work | shaun | OpenFOAM Installation | 12 | March 23, 2007 08:55 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
