Boundary condition on imported solid.
Old   November 29, 2013, 00:13
Default Boundary condition on imported solid.
MP
Mariusz is on a distinguished road
Could someone help me with the following question.
I'd like to consider flow domain as shown in attachment: This is a 3D case, where inside a box (represented on a drawing by a large rectangle) there is a cylinder (represented on a drawing by small rectangle). This cylinder is generated using blender and saved for example as stl file. Geometry would be meshed using snappyHexMesh.
The question is:
Is it possible to define a boundary condition (velocity inlet) on a face of imported stl solid?
Best regards,
Mariusz.
Mariusz is offline   Reply With Quote
Old   November 30, 2013, 07:04
Nima Samkhaniani
nimasam is on a distinguished road
you can define a patch for stl file, so you can assign what BC you like
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Regarding Boundary Condition at Outlet for gas-solid simulation shubham208011 FLUENT 0 July 11, 2013 15:21
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
No-slip condition for non-resolved boundary layer in open channel banks Lupocci Main CFD Forum 1 January 17, 2013 03:11
How To Convert Fluid wall in Solid Wall Boundary Condition RGN FLUENT 4 March 31, 2009 04:43
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
