Setting initial fields using a data file for positions
Old   December 8, 2013, 23:21
Default Setting initial fields using a data file for positions
Christian Butcher
chrisb2244 is on a distinguished road
So I'm currently trying to set the initial conditions on my temperature and/or alpha1 fields using funkySetFields.
The case is 2D (or at least, empty on the back and front) and is basically split horizontally in the middle, with a step function for alpha1, and possibly temperature if I try and use it (I have a modified interFoam solver that seems to be working)
I want to perturb my interface based on a summation of cos waves at different wavenumbers. I have funkySetFields working if I want to use something like
	variables "Curve=cos ((2*pos().x*pi*1)/(max(pos().x)-min(pos().x)));";
		field alpha1;
		condition "((pos().y - ((((max(pos().y)-min(pos().y))/2.0)+min(pos().y)) - 0.005*Curve)) < 0)
but this as far as I can tell only allows one wavelength/number.
I wrote a c++ program to sum up the effects of multiple wavenumbers, giving me a position for each value of x that OpenFoam will ask for (although I don't know how many decimal places that OF uses...), then tried to use those as variables - I have since realised this is likely flawed from the get-go since I would need funkySetFields to read in the pos().x variable, and then after that check for variables to substitute.
Having decided that approach is unlikely to work, I now am trying to see if I can in some way write out my data to be interpreted as a vector, and index my vector by cell location. My thoughts are something like (for a 600 cell wide computational volume/area)
datafile:
defaultVariables (
"value[0 (or 1?)]=1.234;"
"value[1]=1.252;"
"value[2]=...;"
"value[599 (or 600?)] = 1.102;"
with funkySetFieldsDict:
header...
#include "../valuesfile"
expressions
sectiontobechanged
          variables $defaultVariables;
          field alpha1;
          condition "((pos().y - value[(pos().x*600)]) < 0";
          expression "1";
This might still never work, since I guess it will still have to run through in order to give a value to pos().x, and the variable to be chosen (assuming it will allow a vector/array) would need to be selected afterwards.
If anyone knows of a way I could make this work, or alternatively, has some better implementation, please let me know
Christian
chrisb2244 is offline   Reply With Quote
funkysetfields, initial conditions, initialisation, openfoam 2.2, swak4foam
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
