Creating an internal patch
Old   April 3, 2014, 11:14
Default Creating an internal patch
OR
mxpxer7 is on a distinguished road
I'm running a multiphase case where I have water leaving a tank and then falling through a volume of air to the ground. I'm trying to figure out my mass flow rate out of the tank. From What I've read I need a patch at the exit of the tank.
I'm using Salome to generate a mesh. The issue im having is creating a patch between my tank and my volume of air...
So I guess ultimately my question is, does anyone know how to create a patch internal to my mesh?
mxpxer7 is offline   Reply With Quote
Old   April 24, 2014, 09:28
sajad
seju is on a distinguished road
dear my friend
when you use a Salome you must creat a face from your file and choose a name for that for example "Outlet" and when you read your file in openfoam you can see a boundry in constant>polyMesh>Boundry
after that you can define this boundry in 0 folder for BC.
best regards
Sajad
seju is offline   Reply With Quote
Old   June 13, 2014, 05:07
Martin K
Martin_K_lalelu is on a distinguished road
hi,
sorry if I misunderstand you, but that seems not to be working for internal faces. Instead I get a faceZone.
Did you manage to create an internal patch to calculate your mass flux with?
Martin_K_lalelu is offline   Reply With Quote
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[snappyHexMesh] Boundary Patch definition on Thin Surfaces / Internal Walls in SnappyHex Hannes_Kiel OpenFOAM Meshing & Mesh Conversion 4 August 27, 2013 01:06
[Gmsh] Single volume Mesh gmsh PeteH OpenFOAM Meshing & Mesh Conversion 9 August 6, 2013 08:54
[Commercial meshers] FluentMeshToFoam CRT OpenFOAM Meshing & Mesh Conversion 3 May 24, 2012 16:07
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
