[swak4Foam] #codeStream options & includes, swak4Foam |
July 15, 2015, 10:47 |
mike
Rep Power: 10 |
(*updated code below*)
(*I've included, near the top, the code that didn't work, and I have the final, working, code at the bottom.*) Last edited by dEntropy; July 29, 2015 at 05:07. Reason: updated code, posted new, should have just updated code in this post |
July 15, 2015, 10:49 |
mike
Rep Power: 10 |
...and my searching has gotten me to this point (it was all much worse when I started).
i appreciate the help. thank you. |
July 15, 2015, 23:29 |
mike
Rep Power: 10 |
well, I've played around with all sorts of things. The current conditions are as below:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type groovyBC; valueExpression #codeStream { codeInclude #{ #}; codeOptions #{ -I$(LIB_SRC)/groovyBC/lnInclude -I$(LIB_SRC)/swakFunctionObjects/lnInclude -I$(LIB_SRC)/swakTopoSources/lnInclude -I$(LIB_SRC)/simpleSearchableSurfaces/lnInclude -I$(LIB_SRC)/swak4FoamParsers/lnInclude -I$(LIB_SRC)/swakSourceFields/lnInclude #}; code #{ //SI units, please const scalar Reynolds=60; const scalar a=0.0012; const scalar b=0.0012; const scalar rho=997.1; const scalar eta=0.00091; const scalar Pi=3.14159265359; const scalar beta=3*Reynolds*pow(eta,2)*a*b/(4*b*pow(a,3)*rho)*pow(1-(192*0.003825*a)/(pow(Pi,5)*b),-1); int s=0; for (int i=1;i<=99999;i+=2) { s+=(pow((-1),(.5*i-.5))*(1-Re(cosh((i*Pi*fpos().z)/(2*a)))/Re(cosh((i*Pi*b)/(2*a))))*(cos(i*Pi*fpos().y/(2*a))/pow(i,3))); } test=-(16*pow(a,2)*beta/(eta*pow(Pi,3)))*s*normal(); os << test; #}; }; value uniform (0 0 0); } outlet1 { type zeroGradient; } fixedWalls { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Error: Reading field p Reading field U Using #codeStream at line 28 in file "/home/mboehm/OpenFOAM/mboehm-2.4.0/swak4Foam_2.x/Examples/straightDuct_VelocityProfileInletBC/0/U.boundaryField.inlet1" Using #codeStream with "/home/mboehm/OpenFOAM/mboehm-2.4.0/swak4Foam_2.x/Examples/straightDuct_VelocityProfileInletBC/dynamicCode/platforms/linux64GccDPOpt/lib/libcodeStream_1578c42d908c22e7136dbfd27e503fcb4c57 f809.so" Creating new library in "dynamicCode/_1578c42d908c22e7136dbfd27e503fcb4c57f809/platforms/linux64GccDPOpt/lib/libcodeStream_1578c42d908c22e7136dbfd27e503fcb4c57 f809.so" Invoking "wmake -s libso /home/mboehm/OpenFOAM/mboehm-2.4.0/swak4Foam_2.x/Examples/straightDuct_VelocityProfileInletBC/dynamicCode/_1578c42d908c22e7136dbfd27e503fcb4c57f809" linux64GccDPOpt/options:60: *** commands commence before first target. Stop. wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/mboehm/OpenFOAM/mboehm-2.4.0/swak4Foam_2.x/Examples/straightDuct_VelocityProfileInletBC/dynamicCode/_1578c42d908c22e7136dbfd27e503fcb4c57f809 --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/_1578c42d908c22e7136dbfd27e503fcb4c57f809/platforms/linux64GccDPOpt/lib/libcodeStream_1578c42d908c22e7136dbfd27e503fcb4c57 f809.so" file: /home/mboehm/OpenFOAM/mboehm-2.4.0/swak4Foam_2.x/Examples/straightDuct_VelocityProfileInletBC/0/U.boundaryField.inlet1 from line 27 to line 27. From function functionEntries::codeStream::execute(..) in file db/dictionary/functionEntries/codeStream/codeStream.C at line 177. FOAM exiting Last edited by dEntropy; July 16, 2015 at 10:10. |
July 15, 2015, 23:30 |
mike
Rep Power: 10 |
my obvious problems are i don't know C++. seriously, i like openFoam, but i just cannot do the simple calculations i need.
in mathematica, easy. matlab, easy. c++, impossible. Last edited by dEntropy; July 16, 2015 at 10:20. |
July 15, 2015, 23:43 |
mike
Rep Power: 10 |
Let me explain what I'm trying to do:
I have a quasi-analytical solution for the velocity profile in a duct (that's the set of equations). Unfortunately, this solution comprises an infinite sum of trigonometric functions that depend on the y & z positions (because the velocity profile in 3D has only one non-zero term, i.e., Ux, which is dependent on two spatial positions, i.e., y & z). I want openFoam to do the calculations for me. Easy as would involve me using Mathematica to solve the equation, saving in a text file then using that text file as the inlet conditions. However, this take two programs and increases the likelyhood that I use the wrong constants in the equation. So, I thought that pos().y & pos().z was my way to put each individual y & z position into the equation, solve and have a velocity at every location on the inlet face. I thought normal() made my value a vector, with Uy & Uz components = 0. |
July 16, 2015, 02:40 |
mike
Rep Power: 10 |
woops, I guess pos() access internal regions (because it expects a vector). Since I'm applying a boundary condition, I've changed to fpos() so as to access the surface. Sound right?
July 20, 2015, 17:14 |
#7 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Have a look at http://openfoamwiki.net/index.php/Co...er_information (the presentation from the 9th workshop might be a good start). But codestreams don't work with groovyBC. If you want to use them use the coded-BC that comes with OpenFOAM
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
July 20, 2015, 19:28 |
mike
Rep Power: 10 |
Thank you, Bernhard I read through the slides. I can tell you've put a substantial amount of time into this.
I'm afraid I wasn't able to solve my problem, however. It would seem that people take for granted that fpos() or pos() or normal() work in any given code. Unfortunately, I receive the following errors (associated code included below): /home/mboehm/OpenFOAM/mboehm-2.4.0/run/MySimulations/straightDuct_VelocityProfileInletBC/0/U.boundaryField.inlet1:45:49: error: ‘fpos’ was not declared in this scope /home/mboehm/OpenFOAM/mboehm-2.4.0/run/MySimulations/straightDuct_VelocityProfileInletBC/0/U.boundaryField.inlet1:47:4: error: ‘os’ was not declared in this scope /home/mboehm/OpenFOAM/mboehm-2.4.0/run/MySimulations/straightDuct_VelocityProfileInletBC/0/U.boundaryField.inlet1:47:55: error: ‘normal’ was not declared in this scope Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type codedFixedValue; value uniform (0 0 0); redirectType parabolicSquareProfile; code #{ //SI units, please const scalar Reynolds=60; const scalar a=0.0012; const scalar b=0.0012; const scalar rho=997.1; const scalar eta=0.00091; const scalar Pi=3.14159265359; const scalar beta=3*Reynolds*pow(eta,2)*a*b/(4*b*pow(a,3)*rho)*pow(1-(192*0.003825*a)/(pow(Pi,5)*b),-1); scalar s=0; for (int i=1;i<=99999;i+=2) { s+=(pow((-1),(.5*i-.5))*(1-(cosh((i*Pi*fpos().z)/(2*a)))/(cosh((i*Pi*b)/(2*a))))*(cos(i*Pi*fpos().y/(2*a))/pow(i,3))); } os << -(16*pow(a,2)*beta/(eta*pow(Pi,3)))*s*normal(); #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude #}; }; } outlet1 { type zeroGradient; } fixedWalls { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // |
July 21, 2015, 05:07 |
#9 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
July 27, 2015, 03:37 |
#10 |
mike
Rep Power: 10 |
First, thanks to those commenting. Also, thanks to Christian at OIST--he wrote the pivotal pieces of the codestream.
So, I went with standard openFoam (i.e., no swak4Foam) and used the #codeStream functionality (code shown below). I also had to be certain about the formatting near the codeOptions library includes because my compiler settings wasn't properly tabbing in the output inside the DynamicCode folder (which is made when running pisoFoam). The code below solves the analytical solution of the Poisson equation, applies that to the inlets ...and bob's your uncle. I hope others find this useful. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet1 { type codedFixedValue; value uniform (0 0 0); redirectType parabolicSquareProfile1; code #{ const double Reynolds = 30; const double width = 0.0012; const double height = 0.0012; const double a=0.5*width; const double b=0.5*height; const double maxZ=.0012; const double minZ=0; const double maxX=0.0132; const double minX=0.012; const double Dh=4*width*height/(2*width + 2*height); const double Area=(width*height); const double rho=997.1; const double eta=0.00091; const double Pi=3.14159265359; const double beta=(3*Area*Reynolds*std::pow(eta,2))/(4*std::pow(a,3)*b*rho*Dh*0.421731); // We start with a fixedValueFvPatchField. const fvPatch& patch = this->patch(); const vectorField ¢res = patch.Cf(); const double zCentral=maxZ-0.5*(maxZ-minZ); const double xCentral=maxX-0.5*(maxX-minX); Field<vector> newValues(this->patchInternalField()); forAll(newValues, c) { vector centre = centres[c]; const double z = centre.z(); const double x = centre.x(); double s = 0; for (int i=1;i<=99;i+=2) { s+= (std::pow((-1),(.5*i-.5))*(1-(cosh((i*Pi*std::abs(z-zCentral))/(2*a)))/(cosh((i*Pi*b)/(2*a))))*(cos(i*Pi*std::abs(x-xCentral)/(2*a))/std::pow(i,3))); } double value = (16*std::pow(a,2)*beta*s) / (eta*std::pow(Pi,3)); newValues[c] = vector(0, value, 0); } this->operator==(newValues); #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; codeInclude #{ #include "fvCFD.H" #include <cmath> #include <iostream> #}; } inlet2 { type codedFixedValue; value uniform (0 0 0); redirectType parabolicSquareProfile2; code #{ const double Reynolds = 30; const double width = 0.0012; const double height = 0.0012; const double a=0.5*width; const double b=0.5*height; const double maxZ=.0012; const double minZ=0; const double maxX=0.0132; const double minX=0.012; const double Dh=4*width*height/(2*width + 2*height); const double Area=(width*height); const double rho=997.1; const double eta=0.00091; const double Pi=3.14159265359; const double beta=(3*Area*Reynolds*std::pow(eta,2))/(4*std::pow(a,3)*b*rho*Dh*0.421731); // We start with a fixedValueFvPatchField. const fvPatch& patch = this->patch(); const vectorField ¢res = patch.Cf(); const double zCentral=maxZ-0.5*(maxZ-minZ); const double xCentral=maxX-0.5*(maxX-minX); Field<vector> newValues(this->patchInternalField()); forAll(newValues, c) { vector centre = centres[c]; const double z = centre.z(); const double x = centre.x(); double s = 0; for (int i=1;i<=99;i+=2) { s+= (std::pow((-1),(.5*i-.5))*(1-(cosh((i*Pi*std::abs(z-zCentral))/(2*a)))/(cosh((i*Pi*b)/(2*a))))*(cos(i*Pi*std::abs(x-xCentral)/(2*a))/std::pow(i,3))); } double value = -1*(16*std::pow(a,2)*beta*s) / (eta*std::pow(Pi,3)); newValues[c] = vector(0, value, 0); } this->operator==(newValues); #}; codeOptions #{ -I$(LIB_SRC)/finiteVolume/lnInclude \ -I$(LIB_SRC)/meshTools/lnInclude #}; codeInclude #{ #include "fvCFD.H" #include <cmath> #include <iostream> #}; } outlet1 { type zeroGradient; } outlet2 { type zeroGradient; } fixedWalls { type fixedValue; value uniform (0 0 0); } } // ************************************************************************* // Last edited by dEntropy; July 29, 2015 at 05:08. |
July 29, 2015, 05:10 |
#11 |
mike
Rep Power: 10 |
One note: when you name the codeStream (e.g., parabolicflowprofile1 or parabolicflowprofile2) you need to be certain to name each instance something different. if you do not, the solver will still solve but all boundaries sharing that codestream will also share values for, e.g., velocity. So, the code solves...but solves wrong.
[swak4Foam] difficulties installing swak4foam | newbie29 | OpenFOAM Community Contributions | 120 | October 21, 2022 04:01 |
InterDyMFoam+simpleFunctionObject | Elham | OpenFOAM Running, Solving & CFD | 5 | July 10, 2017 11:59 |
fluent text command doesnt show all options! | m2montazari | FLUENT | 3 | March 12, 2017 23:56 |
source term in near wall cell | rajcfd | OpenFOAM Pre-Processing | 5 | February 1, 2016 10:31 |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 13:00 |
