C8H18 implement into dieselFoam
Old   December 13, 2009, 14:58
Default C8H18 implement into dieselFoam
Peter_600 is on a distinguished road
Hi!
I have a problem with the implementation of C8H18 into my case.
I 'd like to inject C8H18 into my engine. I am using the same chem.inp therm.dat files as in the dieselFoam tutorial.
I added C8H18 into the chem.inp file and did all necessary changes to the other scripts, like in the tutorial.
I don t succeed to run the case, with that fuel composition.
Why does it work, with a composition of C7H16- C6H14, like in the tutorial ,but not with C7H16 -C8H18.
... this is the message of OpenFOAM
C8H18 not found in table. Valid entries:
820
CL3SISICL
A2C2HB*
SIF3NH2
OCHNNHO
S-TRIAZINE
NAO-
From function HashTable<T, Key, Hash>:perator[](const Key&) const
in file /home/peter/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude/HashTableI.H at line 128.
FOAM exiting
I appreciate any help!
Peter
Peter_600 is offline   Reply With Quote
Old   December 13, 2009, 21:45
Karl-Johan Nogenmyr
kalle is on a distinguished road
Hi Peter!
The problem is likely that C8H18 is not included in your thermo file. You'll need an entry there for each species in your composition. Which reaction mechanism do you use? Sometimes the provider of the mechanism will also provide thermodynamic data. At least they should state which data they used. A bit of googling should help you to find the required data.
Good luck
Kalle
kalle is offline   Reply With Quote
Old   December 14, 2009, 10:06
Hi Kalle!
Thx for the quick replay.
In ur opinion, I just need a valid entry of C8H18 in my therm.dat.
I already tried it, but just by stupid replacing of a specie by C8H18 ( of course it doesn t make physicaly sense, but it should work. Or I am wrong?
I tried different kind of settings but nothing worked.
I am using the chem.inp and therm.dat file from the tutorial dieselFoam.
The one equation reaction mechanism with C7H16 and by adding a second liquid (C8H18). Its similar to the the tutorial settings, but instead of using C6H14 as second liquid, I try to use C8H18.
thx in advance
Peter
Old   December 14, 2009, 10:50
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
can you attach the non-working case
niklas is offline   Reply With Quote
Old   December 14, 2009, 12:10
Hi Niklas,
I solved my problem by myself. It was a stupid mistake.
I referred all the time to a wrong therm.dat file.
The path in the thermophysicalProperties file for the therm.dat was
CHEMKINThermoFile "~OpenFOAM/thermoData/therm.dat";
I just changed it to
CHEMKINThermoFile "$FOAM_CASE/chemkin/therm.dat";
Where i actually did my changes according to the therm.dat.
Now, I will try to use the real chem.inp file with the corresponding therm.dat.
Thank u anyway for offering ur help.
I appreciate it.
Best regards
Peter
Old   July 1, 2011, 07:16
Default Implement new liquid
Vitaly
vitvit is on a distinguished road
I searched the web for simple steps for adding new liquid to OF without any luck.
I know all the polynomial coefficients and I have the files ready, I just don't know how to compile them - a stupid problem, I know..
can anyone help me?
a simple example step by step on one of the liquids in OF would be nice.. say rename H2O to WATER and compile it. many thanks!!
vitvit is offline   Reply With Quote
Old   November 4, 2015, 05:16
user10600 is on a distinguished road
Hi Peter !
What coefficient values did you put into your therm.dat file for the specie C8H18 ?
Thanks in advance!
user10600 is offline   Reply With Quote
injector model in dieselFoam leejc OpenFOAM 8 April 3, 2018 12:30
gasoline spray simulation using dieselFoam qhdgj OpenFOAM Running, Solving & CFD 10 July 10, 2016 01:55
dieselFoam: how to implement thermo for liquid/gas continuous phase natrask OpenFOAM Running, Solving & CFD 1 July 16, 2009 05:37
axi-symmetric mesh of dieselFoam az1362f OpenFOAM Running, Solving & CFD 2 June 27, 2009 11:32
DieselFoam does not restart from latestTime lord_kossity OpenFOAM Bugs 8 February 21, 2009 13:54
