March 31, 2016, 10:54 |
Problem running solver
A Russell
Rep Power: 10 |
I have a controlDict file that looks like the one below, created in notepad and the extension is removed for foam. What would the problem be? The error given is "problem while reading header for object controlDict".
\***************************** C++*********************************************** *******/ | ===== | \\ / Field | OpenFOAM: The Open Source CFD Toolbox j | \\ / Operation | Version: 2.2.1 | \\ / And | Web: www.OpenFOAM. org j | \\ / Manipulation // ************************************************** ****************************************** // FoamFile { version 2.0 ; format ascii ; class dictionary; location "system"; object controlDict; } // ************************************************** ****************************************** // application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 5; deltaT 0.005; writeControl timeStep; writeInterval 20; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; //************************************************** **************************************** // |
March 31, 2016, 17:57 |
Vinícius da Costa Ávila
Rep Power: 10 |
The first lines should be commented out, but your slash is reversed there. This "/*" starts a comment and this "*/" ends it. You have \*. Just correct it and I think it should work. Edit: /***************************** C++*********************************************** *******\ | ===== | \\ / Field | OpenFOAM: The Open Source CFD Toolbox j | \\ / Operation | Version: 2.2.1 | \\ / And | Web: www.OpenFOAM. org j | \\ / Manipulation \************************************************* **************************************/ This should work
Vinícius dC.A. |
April 1, 2016, 05:24 |
A Russell
Rep Power: 10 |
Thank you, it has now got past the controlDict file but gets stuck in the blockMeshDict file now. I can't for the life of me see what the problem with the file is. When I compare it to the tutorial files it looks identical to me (aside from the different boundaries actually defined. Can you see anything wrong with this below?
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0) (20 0 0) (20 1 0) (0 1 0) (0 0 0.1) (20 0 0.1) (20 1 0.1) (0 1 0.1) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) ); edges ( ); boundary ( top { type wall; faces ( (3 7 6 2) ); } bottom { type wall; faces ( (1 5 4 0) ); } inlet { type patch; faces ( (0 4 7 3) ); } Outlet { type patch; faces ( (2 6 5 1) ); } frontAndBack { type empty; faces ( (0 3 2 1) (4 5 6 7) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
April 1, 2016, 05:40 |
A Russell
Rep Power: 10 |
Apologies please ignore this, I somehow had two blockMeshDict files in the case folder and it was reading the wrong one.
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
solver stop problem in Lagrangian Particle Tracking | sakurabogoda | CFX | 3 | October 5, 2012 06:09 |
Problem Interface Solid Fluid with wall velocity Solver v12 | hills1 | CFX | 2 | October 12, 2009 05:36 |
Compilation problem after modifying a solver. | PetSul | OpenFOAM Running, Solving & CFD | 2 | October 1, 2009 17:28 |
Coupled problem running in parallel | liu | OpenFOAM Running, Solving & CFD | 1 | June 24, 2005 05:57 |
