Difference between wall and patch boundaries for inviscid flow
Old   April 26, 2017, 05:50
Default Difference between wall and patch boundaries for inviscid flow
Jim
jimteb is on a distinguished road
Is there a difference between the wall and patch boundaries when considering inviscid flow (i.e. mu=0, slip at walls for velocity, no turbulence model)? Would I be right to say that the wall and patch types have the same effect under these conditions?
To test this I ran the pitzDaily case using rhoPimpleFoam, with mu=0, slip at the "wall" for velocity, and no turbulence model. This was ran separately with patch and wall boundaries for the "wall". I could not see any difference between the two, where comparing the pressure and velocity contours. However, I am not sure whether this will be the case in other scenarios.
Thanks
jimteb is offline   Reply With Quote
Old   April 26, 2017, 06:18
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You need the wall boundary only if you want to use wall functions.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   April 26, 2017, 06:23
Jim
Thanks, I understand your point. I am still curious as to whether the wall and patch boundaries are essentially equivalent for inviscid flow?
boundary condition, inviscid flow, patches, wall boundary condition
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) cfdonline2mohsen OpenFOAM 3 October 21, 2013 09:28
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
