2 phase turbulent open channel
Like Tree2Likes
  • 1 Post By Madi
  • 1 Post By wavefunction
Old   June 23, 2016, 14:06
Default 2 phase turbulent open channel
Madeleine
Madi is on a distinguished road
Hello Foamers,
I'm quite new in OpenFoam and i try to make a 2 phase turbulent open Channel vor my Master Thesis. Now there a a few very anoying problems.
When I run my simulation the result isn't what i accpected. Normally the water should have the velocity which I have choose, and the air (atmosphere) above the water should have the velocity zero. That doesn't fit in my case (see pictures). How can I solve it?
Also my water level should be constant in the inlet and the outlet. Which isn't the case.
Tank you for your help
Madi is offline   Reply With Quote
Old   July 7, 2016, 06:35
Default freestream
Taher Chegini
Taataa is on a distinguished road
Hi Madi,
The problem is probably related to the BCs. Use freestream and freestreamPressure boundary conditions for inlet and outlet.
p_rgh:
    inlet/outlet
        type            freestreamPressure;
p:
    inlet/outlet
        type            calculated;
U/k/epsilon:
    inlet/outlet
	type			freestream;
	freestreamValue		$internalField;
Hope this help.
Taataa is offline   Reply With Quote
Old   July 7, 2016, 07:44
Madeleine
Hello Taataa,
thanks for your help. I change my BC's but when I now try to run my model i get the following error:
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 ? in "/lib64/libc.so.6"
#3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/interFoam"
#5 Foam::incompressible::RASModels::kEpsilon::correct () in "/opt/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#6 ? in "/opt/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/interFoam"
#7 __libc_start_main in "/lib64/libc.so.6"
#8 ? in "/opt/OpenFOAM/OpenFOAM-2.4.0/platforms/linux64GccDPOpt/bin/interFoam"
Gleitkomma-Ausnahme (Speicherabzug geschrieben)
I work on this case for a while and have fixed the problem with the constant water level at the inlet and outlet. But my veolcities at the inlet and outlet are so much higher than the inlet velocity I put some pictures and my file cases in the attachement. The blue ones are my original BC's which i have changed into your proposal. It would be grate when you can help me again.
Madi
Old   July 7, 2016, 08:03
Taher Chegini
I looked through your case and found this problem:
Change alpha BC to:
inlet/oulet
    	type			calculated;
    	value			$internalField;
Old   July 7, 2016, 08:26
Madeleine
Hey Taataa,
thanks for your fast answer. But now I have the following error
valueInternalCoeffs cannot be called for a calculatedFvPatchField
on patch inlet of field alpha.water in file "/work/ber/Rinne_2Phasen_turb/0/alpha.water"
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<Type>::valueInternalCoeffs( const tmp<scalarField>&) const
in file /opt/OpenFOAM/OpenFOAM-2.4.0/src/finiteVolume/lnInclude/calculatedFvPatchField.C at line 154.
Bashar likes this.
Old   April 5, 2017, 20:53
Bashar
Bashar is on a distinguished road
Originally Posted by Madi View Post
Hey Taataa,
I have similar error in my case, did you manage to solve this error?
Bashar
Bashar is offline   Reply With Quote
Old   April 20, 2018, 08:41
Default Same error
Saicharan
wavefunction is on a distinguished road
Hi all.
Even I have the same error. Did anyone manage to solve it? In my case my field is not even present in the 0/ folder.
Elham likes this.
wavefunction is offline   Reply With Quote
Old   May 18, 2018, 18:46
Daniel W Theobald
pm11dt is on a distinguished road
Hi everyone,
I am also having the same issue with my case.
Has anyone found an answer to this issue?
Probably spent a total of 100 hours scrolling through these forums and no one seems to able to answer this question!
pm11dt is offline   Reply With Quote
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
Turbulent transition in channel flow yansheng STAR-CCM+ 11 June 16, 2016 09:05
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
Yacht in Open Channel Flow andreimour FLUENT 1 October 14, 2010 23:54
