November 10, 2016, 12:16 |
rotatingWallVelocity doesn't work properly
Rep Power: 10 |
Hey,
I wanted to simulate a moving belt (2 parallel sides sliding in different directions. 2 ends rotating) with iddes. OpenFoam 2.3 I get kinda strange results. my boundary conditions for U: dimensions [0 1 -1 0 0 0 0]; internalField uniform ( 0.05 0. 0. ); boundaryField { beltDown { type movingWallVelocity; value uniform (0.05 0. 0.); } beltUp { type movingWallVelocity; value uniform (-0.05 0. 0.); } inlet { type fixedValue; value uniform (0.05 0. 0.); } inlOut_down { type inletOutlet; inletValue uniform (0. 0. 0.); value uniform (0. 0. 0.); } inlOut_up { type inletOutlet; inletValue uniform (0. 0. 0.); value uniform (0. 0. 0.); } outlet { type inletOutlet; inletValue uniform (0. 0. 0.); value uniform (0. 0. 0.); } rotBack { type rotatingWallVelocity; origin (-2.99 0. 0.); axis (0. 0. 1.); omega 10; } rotFront { type rotatingWallVelocity; origin (0. 0. 0.); axis (0. 0. 1.); omega 10; } symBack { type symmetryPlane; } symFront { type symmetryPlane; } } The radius of the belt is 5 mm. The speed 0,05 m/s. So omega should be 10 [rad/s], right? But I get results like on the pictures It doesn't make any sense for me. 30? It isn't even an scalling problem. On both sides the same appears, so the centers of rotation should be ok. The velocity in the field and on other BC is as it should be (U=0.05). What' going on? Could anybody help me? Even if I scaled it to rps, it stll was 95 times too big. P.S. Paraview works with meters, right? Last edited by The_Kaiser; November 10, 2016 at 12:45. Reason: problems with pictures |
November 10, 2016, 12:58 |
Rep Power: 10 |
I found the problem. Is it possible to delete the threat? I mixed the BC names...
Companies that lease software & hardware for cloud-based work? | Catthan | ANSYS | 0 | June 18, 2014 10:53 |
Do all CFD analysts have to do some hands-on work except PhDs? | e13drd | Main CFD Forum | 2 | March 17, 2014 14:56 |
OpenFOAM does not work any more! | kiddmax | OpenFOAM Installation | 12 | June 25, 2013 02:56 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
