Uniform line sampling nonuniform output
Old   March 5, 2008, 03:00
Default Hello, i have a problem creat
Tobias Holzinger
woody is on a distinguished road
i have a problem creating a uniform line sample. I want to read out parameters on a line in radial direction of a axis-symmetric case. Therefore I just copied and adapted the tutorial sampleDict. The sampling process is working, but the radial distances consist of four discontinuities I can't explain. These steps are 2 orders of magnitude larger than the other, equal distances.
My blockMeshDict is:
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0) /* 0 */
(0.999048222 -0.043619387 0) /* 1 */
(0.999048222 0.043619387 0) /* 2 */
(0 0 120) /* 3 */
(0.999048222 -0.0436193870 120) /* 4 */
(0.999048222 0.0436193870 120) /* 5 */
blocks
hex (0 1 2 0 3 4 5 3) (33 1 12000) simpleGrading (0.0005 1 1)
edges
and the sample Dict has the following entries:
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object sampleDict;
interpolationScheme cellPoint;
writeFormat raw;
sampleSets
uniform
name Kq_z100;
axis x;
start (0 0 100);
end (0.99 0 100);
nPoints 100;
fields
T
p
U
Is there any error in my sample file??? Thanks for your help!
Tobias Holzinger
Chair of Thermodynamics, TU München
woody is offline   Reply With Quote
Old   February 23, 2009, 05:13
Default Hello Forum, now i found ou
Tobias Holzinger
Hello Forum,
now i found out how to post a picture. Here is my plot of the sampled Temperaturedistribution:
Tobias Holzinger
Help! Sampling! HP FLUENT 0 May 15, 2008 10:29
[OpenFOAM] Output data file on the line of the example zhoubinwx ParaView 0 February 13, 2008 04:59
can "output control " output Nu in expression? prayskyer CFX 3 July 7, 2006 19:37
Sampling on a patch liu OpenFOAM Running, Solving & CFD 3 May 25, 2005 06:52
maximum output line length in fortran under linux Sergei Chernyshenko Main CFD Forum 2 May 11, 2001 07:25
